just ran her... not too happy
hey i just ran her last night. my best run was a 14.7 et was 99.26 with a 2.3 60' . all the other runs were from 15.5-15.1. what was werid was that my clutch would slip in 2nd, 3rd, and 4th around 5500rpms i have a action 1md clutch but i bought used so that maybe the problem but im not sure. i was running about .720 bar(around 10psi) on a JDM d15b in a 95 civic coupe i was hoping for at least low 14s too. all well
Hey, did I just see you at the track?? Red civic coupe??
Whats up mang!
I'm the guy with the White hatch and GSR engine.
I would say fix that clutch. Your traps are good for high 13's.
Whats up mang!
I'm the guy with the White hatch and GSR engine.I would say fix that clutch. Your traps are good for high 13's.
Your mph is good for high 13's. I had a stock slipin clutch and trapped 94(bottle), with the act it went up to 99mph. I would bleed the clutch lines again to make sure there are no air bubbles.
I had a clutchnet with my old setup, and have a clutchmasters for the new one.
Action clutches are good....sounds like you need one that can handle a little bit more TQ.
How can everyone tell when they're clutch is slipping? I know how you can tell when it's REALLY slipping but if you're paranoid like me and not knowing if it's holding the power or not?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx »</TD></TR><TR><TD CLASS="quote">How can everyone tell when they're clutch is slipping? I know how you can tell when it's REALLY slipping but if you're paranoid like me and not knowing if it's holding the power or not?</TD></TR></TABLE>
I would put it in 5th gear cruising around 40mph, floor it for a couple seconds. You will know if its slippin. My situation though, the stock clutch would not slip all motor, but off the bottle it slipped.
When my ACT took a dump, the best way I could describe it is this:
You know the sensation you get when/if you do a burnout? It's like that. I would cruise in 5th, ease up to 4000-4500 rpm to pass someone, then the revs just start going up, but I'm not accelerating. That's when I knew.
