PR3 in LSVTEC good idea ... bad idea...
I'm building on a budget so I want to use the PR3s on my B16A1 on my LSVTEC. Is this a good idea?
I've been told that I'd be running 11.5 compression. And apparently this is more than the more popular ITR pistons. Any reason why more people dun use the PR3? They too high?
thanks!
thanks!
well the reason for the higher cr is that the the b16 has less stroke and the ls will be higher with those then the type r's cus they were desigened for the stroke of a 1.8 here check this out
http://www.c-speedracing.com/h...c.php oh yah and ther both gonna be 11.6 but ones like 11.63 and the other like 11.62 so yah id just use whats cheaper
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racerboyb18c1 »</TD></TR><TR><TD CLASS="quote">well the reason for the higher cr is that the the b16 has less stroke and the ls will be higher with those then the type r's cus they were desigened for the stroke of a 1.8 here check this out
http://www.c-speedracing.com/h...c.php oh yah and ther both gonna be 11.6 but ones like 11.63 and the other like 11.62 so yah id just use whats cheaper </TD></TR></TABLE>
actually the ones that are close are the JDM ITR and the pr3. i bought some pr3s from a guy on h-t, and almost put them in my ls/vtec, buy they came like a month late and i could not have them installed, i had to settle for gsr pistons and now i am running s2stage2 on 10.0:1 cr
i just need to find the time and the money to throw the pr3s in
PR3's are excellent,but you need to upgrade your valvetrain.with the higher compression and hp gain,the head is more susceptible to detonation,not to mention the valvetrain is pushing around 10+years(if it's a 1st gen).
i had a set of type r pistons but if you are using factory rods they have to be machined to fit the r pistons. i returned the r pistons and got pr3's, they dont have to be machined and they have higher compression. i would say go with the pr3.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racerboyb18c1 »</TD></TR><TR><TD CLASS="quote">its a nitrate coating</TD></TR></TABLE>
Type-R pistons are not nitride coated, they are moly coated. The coating holds oil.
not meant for heat protection.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sgT »</TD></TR><TR><TD CLASS="quote">
not meant for heat protection.</TD></TR></TABLE>
have b18c1 block with Ls crank and rods. the p30 pistion is what im missing in search for some help!! i perpher p30 over pr3 because of cr diference. perp b18c1 cylinder head mild port polished, polished chamber 3 angle valve job stage 3 crane cams and valve train jg intake and 65mm throttle. cant wait to build. if anyone being there done that or similar, info would help alot. got most of the parts dirt cheap. hopfully it turn out good or alright
thanks
thanks
