LS VTEC
Old Oct 22, 2005 | 01:22 PM
EkPudge's Avatar
Default LS VTEC
i am currently building ls vtec for my 93 teg. I have a b18b block wit a 99 gsr head. I just need to know what pistons would be best for my setup(i am going all motor) and what ecu should i use
Old Oct 22, 2005 | 01:32 PM
Micha's Avatar
FAILWGN
Default Re: LS VTEC (dat*****01)
Use B16 (p30) pistons. And you will have to use a chipped ECU. Get a P28 and get your car tuned.
Old Oct 22, 2005 | 01:42 PM
EkPudge's Avatar
Default Re: LS VTEC (Blu99teg)
will the b16 pistons drop right in and will they fit on ls rods
Old Oct 22, 2005 | 01:53 PM
ricebucket's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dat*****01 &raquo;</TD></TR><TR><TD CLASS="quote">will the b16 pistons drop right in and will they fit on ls rods</TD></TR></TABLE>yes
Old Oct 22, 2005 | 02:51 PM
nickG's Avatar
you should find what compression ratio you want, and then pick your pistions...
not because some guy on h-t said so
Old Oct 22, 2005 | 04:39 PM
Richard Noggin's Avatar
From: Good luck to this industry, you're gonna need it.
Default Re: LS VTEC (nickG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nickG &raquo;</TD></TR><TR><TD CLASS="quote">you should find what compression ratio you want, and then pick your pistions...
not because some guy on h-t said so</TD></TR></TABLE>
that's the way, if you want lower compression check out JDM ITR pistons...that's what I used. Kept compression low enough that it's streetable without abnormal maintenance. Go with CTR pistons if you want high compression...TUNE TUNE TUNE good luck
Old Oct 22, 2005 | 05:16 PM
usvispeedracer's Avatar
Default Re: LS VTEC (DAantagonist)
yo can u get this first time on it post means 2 send right
Old Oct 22, 2005 | 05:21 PM
r u getting responces from me
Old Oct 22, 2005 | 06:47 PM
Default Re: (usvispeedracer)
yes, we hear you master...what is your bidding...
Old Oct 22, 2005 | 09:26 PM
EkPudge's Avatar
repost
Old Oct 22, 2005 | 09:35 PM
Sack Master's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DAantagonist &raquo;</TD></TR><TR><TD CLASS="quote">yes, we hear you master...what is your bidding...
</TD></TR></TABLE>LMAO!!!
Old Oct 23, 2005 | 12:26 AM
riceball777's Avatar
if you are going to spend $300 for brand new oem pistons and rings you better off just sepending another $150 for some good forged pistons.
Old Oct 23, 2005 | 03:03 AM
MenaceL.A.671's Avatar
Default Re: LS VTEC (riceball777)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceball777 &raquo;</TD></TR><TR><TD CLASS="quote">if you are going to spend $300 for brand new oem pistons and rings you better off just sepending another $150 for some good forged pistons.</TD></TR></TABLE>
rather just get used ctr... 50$ for a set of ctr (used).
Old Oct 23, 2005 | 02:31 PM
608 Gangsta's Avatar
Default Re: LS VTEC (m2slsvtec)
I got CTR in mine.. tuned with some other goodies puttin down 190 whp
Old Oct 23, 2005 | 06:00 PM
Default Re: LS VTEC (608 Gangsta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 608 Gangsta &raquo;</TD></TR><TR><TD CLASS="quote">I got CTR in mine.. tuned with some other goodies puttin down 190 whp</TD></TR></TABLE>
yo 608, what did you tune with, and how high's your compression...I should have gone CTR, but went JDM ITR instead...wondering how streetable your car is...
Old Oct 27, 2005 | 12:56 PM
yo 608, what did you tune with, and how high's your compression...I should have gone CTR, but went JDM ITR instead...wondering how streetable your car is... </TD></TR></TABLE>
i tuned it with hondata s200, my compression is 13:1 or around there its pretty high, i actually had to put a thick cometic headgasket in to lower the compression but i mean its tuned to 93 octane its an everyday driver. its scoots ~ i take it to 9 .. everything balanced very reliable, it makes power to 9 grand.. so y not right =D
Old Oct 27, 2005 | 01:17 PM
SOHCVTECx2's Avatar
For piston wise, it all depends on how high of compression you want to go. If you want high compression, i always use CP pistons. They are very very reliable. they are still good with stock rods and stock LS crank. But must be (balanced, micropolished, and knifed) for a really good effect along with good HP and TQ gain. ECU i would recommend a p28 with Hondata s2000.
b18bteg14
Jun 2, 2007 01:14 PM
EKB18BPR3
Mar 8, 2007 12:34 AM
PphamEK
15
Sep 21, 2006 06:42 PM
Topdawgg
Jan 13, 2006 09:25 PM
RaceCarRyne
Nov 3, 2005 02:19 PM
