drag3 downpipe with test pipe for cat replacement
i have just the regular drag 3 dp with a test pipe that replaces your cat. the test pipe has 2 bungs on it for 02 sensors. Also the dump from the wastegate goes back into the exhaust. i will post pics later or i can e-mail them to you. The only thing about it is the guy at the exhaust shop instead of clocking the 2 bolt flange that bolts to the test pipe to make it bolt up to my greddy, he clocked my greddy 3 bolt flange
that mother focker!!! so youl will have to have it turned a little so it will bolt up to your exhaust, the dp just has to be cut and then the test pipe and other end of dp will have to be welded into place, this will be a good time to add some flex to it....
200 shipped obo for both.....
that mother focker!!! so youl will have to have it turned a little so it will bolt up to your exhaust, the dp just has to be cut and then the test pipe and other end of dp will have to be welded into place, this will be a good time to add some flex to it....200 shipped obo for both.....
98vsmferio
Apr 27, 2005 01:40 PM
