B18c buildup question
I have searched but am still a little confused, the time has come for a rebuild and need help on which would be the best option.
i will be throwing in ctr pistons .025 over for sure but the part i was debating is should i throw in a ls crank and rods.
i heard this is a good mod to do for building up more torque, but was concerned on valve clearance.
All this will be on gsr block and gsr head
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecvoodoo »</TD></TR><TR><TD CLASS="quote">I`d just keep your GSR Crank and Rods.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whiteinteg95 »</TD></TR><TR><TD CLASS="quote">why would you guys say to do that, alot of people have been saying nothing but good things about puting an ls crank in a gsr. Theres always room for more torque, right?</TD></TR></TABLE>
The torque difference is not that great. We are talking about 1.8mm of stroke here. That's 37cc more displacement for changing the crank, rods, rod bearings, and possibly requiring modifications to the pistons, depending on which pistons you choose. The oil squirters must also be modified, since the LS crank will hit them. Seems like quite alot of hassle for not much to show.
the gsr has a nice stroke, not too long so you can still make nice top end, but not to small so it has no tq. id rather put a type r crank in there.... type r crank has more counterweights ie better to rev high thats why im recommending it...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whiteinteg95 »</TD></TR><TR><TD CLASS="quote">serious, the way people talk about it, it seemed like it would make a world of difference.</TD></TR></TABLE>
Yeah it gets overhyped IMO. If you look at the specs most oft cited for the engines the B18c1 often shows the same or more torque than the B18a/b, just at higher RPMs. Like this:
B18b1 127@5200
B18c1 128@6200
In all fairness to the LS motor though the b18c1 does come stock with .8 more compression.
B18b1 127@5200
B18c1 128@6200
If you already have a GSR crank just have it inspected and balanced and call it a day.
For the rods either GSR or ITR will work. The ITR rods are lighter and stronger. If you stick with the GSR rods you have to use the wrist pins from your GSR slugs as I recall. Are you changing your bearings while you're in there?
are the ctr pistons pretty good in withstanding the stress of a high compression motor that sees a 50 shot of nitrous occasionally ? or should i just go with high compression forged pistons
I wouldnt throw anything around especially if there engine parts.. however if you increase your stroke from 87 to 89mm your car will make more hp and be faster.. but you will need the ls rods.. But that setup works well if done correctly..
What are you going to do with this motor? Drag? Road/Race? I wouldnt waste my time putting in the LS crank in a GSR block. You will gain some low end torque with the bigger stroke, however you change the R/S ratio which will decrease how high your engine can rev safely. Personally, I would stick with the GSR block/crank/rods and maybe go with JDM ITR pistons....but if you want a little more CR then go with CTRs. This will maintain reliability and depending on other mods to the head and boltons you should have a block that will easily support 190whp or more. Good Luck!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cleanEG »</TD></TR><TR><TD CLASS="quote">Also....I agree that if you want to run Nitrous go with forged pistons...but isnt this an "ALL MOTOR" forum....keep it real
Yeah...but NaAwZ is too kewl! YO!
</TD></TR></TABLE>Yeah...but NaAwZ is too kewl! YO!
so you guys run type r rods safely on 200 - 240 whp motors? should those be sufficient.
the reason i mentioned about the nitrous is because it would be nice to know or not if i could get a little 50 shot if i needed to for that little extra boost, you know.
My plan for the motor is a daily driven car thats pretty streetable, tons of tuning of course and i will be taking to the track frequently.
