Greddy A/F gauge: Anyone use this?
Old Sep 30, 2003 | 10:32 AM
symba's Avatar
Default Greddy A/F gauge: Anyone use this?
I'm wondering if anyone has this gauge and how accurate is it. Is it any better than running Autometer A/F?
Old Sep 30, 2003 | 01:21 PM
drvfast's Avatar
Default Re: Greddy A/F gauge: Anyone use this? (symba)
i would like to know this also
Old Sep 30, 2003 | 06:48 PM
M.A.R.C.'s Avatar
Default Re: Greddy A/F gauge: Anyone use this? (drvfast)
same here. althogh i doubt they are any more accurate because they dont' use a wideband o2 for the sensor
Old Sep 30, 2003 | 07:12 PM
GDM Z28's Avatar
Default Re: Greddy A/F gauge: Anyone use this? (CivicRyda2k)
i would imagine it would be the same as the autometer...just another light show lol
Old Sep 30, 2003 | 07:17 PM
95gsrturbo's Avatar
Default Re: Greddy A/F gauge: Anyone use this? (civicflnum1)
no they are not a light show it is a digital meter with analog display and give a pretty accurate reading, i just sold one that was brand new- runs about 340 retail and about 275 online, it comes with its own 4 wire O2, which greddy claims has been claibrated very closely to a five wire WB.
pretty acurate from what ive seen in tuning. i have a friend with one in his car and it follows closely to the WB-- although it lags a bit behind since it takes longer to get the needle to move.
Old Sep 30, 2003 | 07:19 PM
TurboDANDEE's Avatar
Default Re: Greddy A/F gauge: Anyone use this? (95gsrturbo)
its only accurate during WOT. also to make it as close as possible to a 5 wire WB, u have to sit there and calibrate it side by side with another WB because its not tuned/calibrated right out the box.
Old Sep 30, 2003 | 07:21 PM
vtec.dc2's Avatar
Default Re: Greddy A/F gauge: Anyone use this? (TurboDANDEE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboDANDEE &raquo;</TD></TR><TR><TD CLASS="quote">its only accurate during WOT. also to make it as close as possible to a 5 wire WB, u have to sit there and calibrate it side by side with another WB because its not tuned/calibrated right out the box.</TD></TR></TABLE>
when it jumps back and forth, its still accurate.. it shows the cycle and whatever is going on with the car.. i should say relatively accurate
you can't tell how rich your setup is running with narrowband, whether its a lightshow or digital
Old Sep 30, 2003 | 07:22 PM
xenocron's Avatar
NARROWband means there is a very small range in the A/F spectrum where the O2 sensor is remotely accurate. As soon as you stray slightly away from 14.7 A/F...you can kiss knowing what A/F you are actually running.
A 13.5 A/F would be the same as 10.0 and even more dangerous a 15.5 would appear the same as 20.0 A/F
Some gauges have better electronics, better components and a more appealing design thus the cost difference. Doesnt make the sensor anymore or less accurate tho.
Old Oct 1, 2003 | 05:01 AM
GreddySi99's Avatar
Default Re: Greddy A/F gauge: Anyone use this? (xenocron)
they are not accurate for **** do not tune by one of these or car go BOOM trust me get a wideband or have someone with a wideband tune your car. then use the Shitty A/F gauge as a reference
Old Oct 1, 2003 | 06:05 AM
symba's Avatar
Default Re: Greddy A/F gauge: Anyone use this? (intercooledJRSC)
It was really just for reference. My plans are to use the AEM wideband with my Hondata s200. So really, my question is can I use the Greddy as a display for the AEM wideband....I won't have my laptop permanently fixed to the passenger seat and I would like to be able to reference my a/f frequently.
Old Oct 1, 2003 | 06:07 AM
COOKIEPUSS's Avatar
$275, for another $75 you can get a wideband.....which is much better.
Old Oct 1, 2003 | 06:35 AM
symba's Avatar
Default Re: Greddy A/F gauge: Anyone use this? (COOKIEPUSS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by COOKIEPUSS &raquo;</TD></TR><TR><TD CLASS="quote">
$275, for another $75 you can get a wideband.....which is much better.</TD></TR></TABLE>
I will have a wideband.....The AEM...But can I hook up the Greddy gauge to the aem?
Old Oct 1, 2003 | 07:18 AM
vtec.dc2's Avatar
you'll probably have to re-calibrate it.
Old Oct 1, 2003 | 07:21 AM
95gsrturbo's Avatar
Default Re: Greddy A/F gauge: Anyone use this? (vtec.dc2)
i dont think the plugs will match up --greddy wont know how to read the extra wire-- or it wont ground properly... dont know
Old Oct 2, 2003 | 03:32 AM
xenocron's Avatar
You can hook it up if the AEM has a separate analog out signal that can go to your ECU or your guage.
Old Oct 2, 2003 | 06:20 AM
Ricey McRicerton's Avatar
Just do the Techedge DIY kit! Serioulsy, just get a wideband...its worth it....especially when you get one with the readout so you can monitor your A/F ratios all the time!
rasinhell
Audio / Security / Video
Aug 18, 2005 02:43 PM
95accordh22a
May 20, 2005 08:24 AM
Pat
Jan 16, 2003 08:30 PM
TypeR1558
Oct 8, 2002 08:24 PM
One8Hatch
Nov 27, 2001 12:30 PM
