92 Honda Accord electric motor windows move slower in the summer
Old Sep 30, 2003 | 10:31 AM
William G's Avatar
Default 92 Honda Accord electric motor windows move slower in the summer
Has anyone noticed this problem? I would figure that the windows would operate better in the heat and slower in the cold but we had our first cold front come in over the weekend and low and behold I noticed that my power windows are working quite nicely now. During summer months they tend to really drag about mid way up but now that it's in the upper 50's they are moving up and down without a hitch.
Old Sep 30, 2003 | 12:12 PM
philadd's Avatar
Default Re: 92 Honda Accord electric motor windows move slower in the summer (William G)
my 99 accord had the same problem... it ended up being the seal around the door (the side towards the rear of the car). The seal was causing too much friction, making it harder on the motor. Apparently the seal was sitting just a little off and almost wanted to bunch up. I figured it was worse in the summer because the seal expanded in the heat. Don't know if yours is the same problem, but maybe it'll help.
to clarify: when I mention the seal, I'm talking about the one that "frames" the window when the window is rolled up.
Old Sep 30, 2003 | 12:24 PM
William G's Avatar
Default Re: 92 Honda Accord electric motor windows move slower in the summer (philadd)
That makes perfect sense. I wonder if there is anyway to cut down on the friction between the glass and the seal.
Old Sep 30, 2003 | 02:09 PM
jerseybrandon's Avatar
clean and lube the run channel.
Old Sep 30, 2003 | 07:34 PM
fast93accord's Avatar
use spray silicon to spray the runchannels. Spray a lot, and move the window up and down at the same time. Sometime you may have to adjust the window glass in the regultor, so the glass doesnt rub the runchannel so hard.
Old Sep 30, 2003 | 08:55 PM
NathanMorris's Avatar
Default Re: (fast93accord)
silicone spray is godly.......use a lot of it, problem solved
- Nathan
Old Oct 1, 2003 | 12:55 PM
philadd's Avatar
Default Re: (92Lx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92Lx &raquo;</TD></TR><TR><TD CLASS="quote">silicone spray is godly.......use a lot of it, problem solved
- Nathan</TD></TR></TABLE>
That's exactly what I did...
Old Oct 2, 2003 | 09:22 AM
William G's Avatar
Default Oh yeah! Silicone - It's not just for implants anymore:)
Used the silicone spray on my windows and now they work as good as new. Thanks for the heads-up, all.
Now, you think it will work just as good on a dragging power antenna?
Will
Old Oct 2, 2003 | 11:36 AM
juangotti's Avatar
please dont think im a idiot im not too down with the car lingo i have a accord as well and the window go up so damn slow so what exactly are the run channels i would also like to try the silicone spray technique any info on where the channels are exactly helpful thanks guys.....
masti
53
Oct 23, 2016 11:42 AM
manwezy951
Apr 2, 2005 09:14 PM
all420
Jul 11, 2004 09:32 AM
honey_wagon
Sep 16, 2003 12:58 AM
