Is Power Fc plug and play??
Old Sep 30, 2003 | 09:19 AM
JDMITR222's Avatar
Default Is Power Fc plug and play??
I've had the unit for a while just never got around to installing it.Also i lost the instructions to it.I think i remember there was a procedure to do before starting the car,to base program the ecu.
I tried going to Apexi-usa and downloading but my computer is really slllooooowwww.
Any help will be appreciated,you can even pm if you'd like.
Thanks in advance
Justin
Old Sep 30, 2003 | 12:41 PM
baonest1's Avatar
Default Re: Is Power Fc plug and play?? (JDMITR222)
i got an FC. i downloaded a manual, but it was for the RX7. i think somewhere there is the honda manual online, but it was sloww so i dont even know if it was still there.
i tried hooking my FC up a couple weeks ago and my car wouldnt start. i figured it was cuz i had no base map. i just called XS engineering like 30 min ago and they said that it HAS to have a base map on it or else there is something wrong. soooooo ima double check when i get home, but i swear me car wouldnt start.
Old Sep 30, 2003 | 02:12 PM
MiraiZ's Avatar
Default Re: Is Power Fc plug and play?? (baonest)
If you car has only the base map, you will probably need to teach your car to idle. Its a pain in the *** but unless its done, the car will not idle and it will keep stalling.
Old Oct 1, 2003 | 07:04 AM
JDMITR222's Avatar
Default Re: Is Power Fc plug and play?? (MiraiZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiraiZ &raquo;</TD></TR><TR><TD CLASS="quote">If you car has only the base map, you will probably need to teach your car to idle. Its a pain in the *** but unless its done, the car will not idle and it will keep stalling.</TD></TR></TABLE>
Got it on last night.
I had to let it idle for 10 minutes with nothing on at all.
Then another 10 minutes w/the rear defroster on.
Another 10 minutes w/ac on.But i aint got no A/C. .
No more check engine light,doesn't smell like i'm runnin 100 octane anymore either.With the stock ecu it was runnin REAl rich.If i were to let the car idle for 30 minutes with the stock ecu id probablly be dead from the fumes in the garage.
Thanks guys
Old Oct 1, 2003 | 11:45 AM
strepto's Avatar
Isnt the powerFC a pure racing ecu replacement? Unsuitable for street/daily driver?
Old Oct 1, 2003 | 12:02 PM
JDMITR222's Avatar
Default Re: Is Power Fc plug and play?? (strepto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by strepto &raquo;</TD></TR><TR><TD CLASS="quote">Isnt the powerFC a pure racing ecu replacement? Unsuitable for street/daily driver?</TD></TR></TABLE>
Just depends how you want it tuned really.
RACEPAK
Engine Management and Tuning
Apr 29, 2016 07:20 PM
dbb95ex
Mar 7, 2014 02:34 PM
1SLWEJ1
Feb 24, 2011 01:46 PM
legomytego
Nov 8, 2008 05:54 AM
chri5
Nov 16, 2001 06:42 PM
