JDM Red Recaro installation minor ques.
Old Aug 26, 2001 | 07:07 PM
machgo5go's Avatar
Default JDM Red Recaro installation minor ques?
HI all,
Does the JDM Recaros with oem rails is direct bolt on to our USDM ITR?
What about the Seat Belt clip, does it have same plug in seat belt warning or do i have to u the one already in our car?
Thanks for the info.
ed lee
Y2K ITR #498
97 ITR #315 RIP
PS Its good price for $2k for the set?
[Modified by machgo5go, 8:45 PM 8/26/2001]
Old Aug 26, 2001 | 07:12 PM
Saga's Avatar
Default Re: JDM Red Recaro installation minor ques. (machgo5go)
yup bolt on if you have the jdm oem rails
seat belt clip is the same as well...either one would be fine.
Old Aug 26, 2001 | 07:37 PM
Mike M's Avatar
Founding Member
Default Re: JDM Red Recaro installation minor ques. (Saga)
Bolts Right in
Old Aug 26, 2001 | 07:39 PM
machgo5go's Avatar
Default Re: JDM Red Recaro installation minor ques. (TypeRmsm)
Thanks for the answer. So $2K for the set is good buy then??
Old Aug 26, 2001 | 07:52 PM
Mike M's Avatar
Founding Member
2000 for a used set in Good condition is about average
Old Aug 26, 2001 | 10:43 PM
Wet Nudl's Avatar
New User
There's no seat belt warning harness on the JDM ITR seats..
Old Aug 26, 2001 | 11:33 PM
Saga's Avatar
Default Re: JDM Red Recaro installation minor ques. (TypeRP)
...mine comes with it...
I suppose he is referring to the plug for the selt belt light on the cluster...
Old Aug 27, 2001 | 02:40 AM
Back in Black's Avatar
Rather OG
Ditto, mine has the sensor/clip as well.
Old Aug 27, 2001 | 03:54 AM
machgo5go's Avatar
Default Re: JDM Red Recaro installation minor ques. (Darth VadeR)
Another ques. Its there different oem bracket if the seat came from a CTR?
The info i got is the if is a set from DC2 , then its only for DC2 and EG series.
EK brackets from CTR is only for that series?
Thanks again for info.
ed lee
Old Aug 27, 2001 | 05:53 AM
Benjamin Tang's Avatar
ed lee
ek and dc2 rails don't mix... i think th outboard rails will still work, but the inboard ones (ie. seatbelt buckle side) will not.
Old Aug 27, 2001 | 05:56 AM
R1020's Avatar
Default Re: JDM Red Recaro installation minor ques. (Benjamin Tang)
right on, ben is correct on this, the inboard rails are different. although EG and DC2 rails should be the same...
JDM CTR '00
Jul 27, 2008 11:03 PM
EricUSC
Feb 14, 2005 04:52 AM
Mr.Fairlady
Jul 10, 2004 11:06 AM
jeff652
Jan 2, 2004 06:49 AM
jdmspoonitr
Nov 14, 2002 02:34 PM
