auto to manual conversion complete, but having some issues
Old Sep 30, 2003 | 05:06 AM
D_TY3's Avatar
Default auto to manual conversion complete, but having some issues
hey guys i am posting again, i really need some advice
i just finished the conversion this past weekend
just having an issue getting the car started.
i changed the auto ecu with a manual ecu
when i put the key in the ignition the cluster registers its in the "D" drive position
when i crank it i only hear on click
can it be the starter or do i have to re-wire something?
also i dont know if it matters mut i am still using the auto ground wire
thanks in advance
Old Sep 30, 2003 | 06:57 AM
Big Bang's Avatar
Default Re: auto to manual conversion complete, but having some issues (D_TY3)
did you ground out the neutral safety switch? If you didn't i'd bet that's your problem, especailly if it thinks your in drive.
Mark
Old Sep 30, 2003 | 07:56 AM
D_TY3's Avatar
Default Re: auto to manual conversion complete, but having some issues (The Converted)
thanks for the quick reply
is the neutral saftey switch on the clutch pedal?
if so i wired those up to the old auto harness in the shifter console.
if not can you clarify on the location, i dont have the helms manual in front of me.
i did more searching and found some info.
basically it said to hook up the old auto slider and put the car in park
then start it. I will try this later tonite.
any other insight would be appreciated.
thanks
Old Sep 30, 2003 | 09:21 AM
Big Bang's Avatar
It's the part on the tranny that tells the car what gear it's in. So you basicly have to trick it into thinking it's in park.
Old Sep 30, 2003 | 09:27 AM
D_TY3's Avatar
The Converted,
Thanks, I will look into it
XxD16xX
Nov 29, 2014 10:39 AM
juevi
Nov 25, 2012 10:01 AM
hondaACCORD
Apr 10, 2004 11:29 AM
JDMvtecDRAGSTA
Mar 24, 2002 10:47 PM
