oxygen sensor threads... what are they??
Aren't they just a typical spark plug thread? In which case, what thread is that? When I welded up my downpipe, I forgot to put an o2 bung in, and I dont have the welder at my house anymore, so I just wanna go and drill a hole and heli-coil it... And as far as leaks go, its open downpipe, so i'm not worried about that...
well, i DO know its the same thread as the BIGGER spark plug size..whatever is the next step up from the honda 5/8" spark plug...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tinker219 »</TD></TR><TR><TD CLASS="quote">18X1.25 i believe...anyone confirm?</TD></TR></TABLE>
Bingo.
For those looking for cheap o2 bungs, they sell sparkplug antifoulers in the 'Help!' section at most autoparts stores. Around $4 for a pair.
Bingo.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rioninja »</TD></TR><TR><TD CLASS="quote">
Bingo.
For those looking for cheap o2 bungs, they sell sparkplug antifoulers in the 'Help!' section at most autoparts stores. Around $4 for a pair.</TD></TR></TABLE>
i bought one of these but it didnt work... it wasnt just a bung, it was a cylinder type thing, that the o2 sensor wouldnt fit in... I cut the thing in half to try and use it as just the nut, but the threads were wrong... and it was an 18mm size too
Bingo.
thats what i used,it was int he help section.what 02 sensor are you trying to put in it?it should work.you sure you got the right one?i had to cut the tip off mine to let the o2 sensor sit down in it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictypenos »</TD></TR><TR><TD CLASS="quote">thats what i used,it was int he help section.what 02 sensor are you trying to put in it?it should work.you sure you got the right one?i had to cut the tip off mine to let the o2 sensor sit down in it.</TD></TR></TABLE>
hmm... maybe i bought the wrong one... im gonna go back to the zone
rysingsun86
Mar 28, 2007 09:29 AM
suckmypistons
Sep 8, 2006 07:57 AM
Sprockets
Dec 13, 2005 11:32 AM
