Trouble starting 93 Integra
Old Sep 30, 2003 | 04:36 AM
CWBETB's Avatar
Default Trouble starting 93 Integra
Hey guys recently I have been having a problem starting my 93 Integra. It seems to start fine if the engine is cold. If I drive it for a bit and let it sit for a hour or so the car will just crank but wont start. I litterly have to crank it about 30 times and finally it will fire up. I am thinking about replacing the igniter. Anyone have any ideas before I blow my money? Thanks
Old Sep 30, 2003 | 05:47 AM
MikeTV
Guest
Posts: n/a
Default Re: Trouble starting 93 Integra (CWBETB)
yes...I had the same problem with my 92..........your distributor is on the way out.........
Old Sep 30, 2003 | 06:31 AM
CWBETB's Avatar
Default Re: Trouble starting 93 Integra (Eclipse spanker)
Crap I thought they had a recall on the distributers? Maybe I can get it free.
Old Sep 30, 2003 | 09:28 AM
MikeTV
Guest
Posts: n/a
im not sure if they did, but I know I had to buy I new one for 350 $
Old Sep 30, 2003 | 11:36 AM
Ryan3933's Avatar
Have you tried replacing your main fuel relay? I had the same problem. Starts strong when cold, hard to start when hot. Also hard to start during the summer when sitting out in the sun and the cabin temp rises. You could try resoldering the joints in your existing relay or buy a new one for $70.
Old Sep 30, 2003 | 11:56 AM
CWBETB's Avatar
Default Re: Trouble starting 93 Integra (Ryan3933)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ryan3933 &raquo;</TD></TR><TR><TD CLASS="quote">Have you tried replacing your main fuel relay? I had the same problem. Starts strong when cold, hard to start when hot. Also hard to start during the summer when sitting out in the sun and the cabin temp rises. You could try resoldering the joints in your existing relay or buy a new one for $70.</TD></TR></TABLE>
My buddy has a spare Dizzy Im going to try to use tonight. If this doesnt work Im going for the main relay Thanks guys
Old Sep 30, 2003 | 12:16 PM
91tegrals's Avatar
yeah try that dizzy and then shoot for a fuel prob...
Old Sep 30, 2003 | 01:58 PM
b18c-93's Avatar
New User
i work for honda..
i would start with the main relay. take it apart from the cover and look at the contacts real good look to see if they are broken, if so resoder them. and try again
http://www.markl.f9.co.uk/howt...y.htm
Old Oct 1, 2003 | 04:47 AM
CWBETB's Avatar
Default Re: Trouble starting 93 Integra (b18c-93)
b18c-93, thanks for the pics.
My buddy had a Dizzy laying around that I can use and we hooked it up last night. Car runs fine at the moment. This doesnt happen all the time so its tuff to track down. IF the dizzy doesnt resolve the issue Im going to check out what b18c-93 showed me, again guys thanks!
Old Oct 1, 2003 | 06:15 AM
b18c-93's Avatar
New User
thats cool let me know what up
Old Oct 1, 2003 | 06:25 AM
Johnnie's Avatar
New User
I had the same problem and solved by changing the dist. cap, rotor, and ignition coil. The ignition coil is known to go bad around 90-100k.
Old Oct 1, 2003 | 07:38 AM
TEXN3's Avatar
Default Re: (Johnnie)
don't change out the whole distributer...just the cap, rotor and coil. its much much cheaper from an autoparts store then getting a whole new piece from honda.
WEEZY034
Jul 28, 2008 05:16 AM
dkboyny11
Jun 26, 2008 11:49 AM
justincredble
Jun 29, 2005 11:55 AM
KeithsDAteg
Aug 12, 2004 08:41 PM
