chiping prelude,help
Old Sep 30, 2003 | 02:47 AM
racer505's Avatar
Default chiping prelude,help
Hi people,helps me.My car prelude 93,JDM,H22A,ECU P13,NEEDED disable o2 sensor in my ECU,have who ROM EDITOR or ready ROMs? HOPE ON YOUR HELPS,SORRY ME ENGLISH
Old Oct 5, 2003 | 12:07 PM
rasser5050's Avatar
Default Re: chiping prelude,help (racer505)
heey,not who not to want I help???
Old Oct 5, 2003 | 12:54 PM
satan_srv's Avatar
Default Re: chiping prelude,help (rasser5050)
Okay so you need a P13? What ecu are you running now?
I don't recommend any chips for the prelude they are usually all junk.
Old Oct 5, 2003 | 01:05 PM
rasser5050's Avatar
Default Re: chiping prelude,help (satan_srv)
I search rom editor or ready roms with disable o2 sensor,can who have this?
Old Oct 5, 2003 | 02:16 PM
satan_srv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rasser5050 &raquo;</TD></TR><TR><TD CLASS="quote">I search rom editor or ready roms with disable o2 sensor,can who have this?</TD></TR></TABLE>
Are you trying to disable the primary (header) or secondary o2 sensor (cat)?
Old Oct 6, 2003 | 09:53 AM
raser5050's Avatar
In my country very bad fuel,o2 sensor quickly perish,I has tired to buy new,I want desabled o2 sensor in my ECU,THIS POSSIBLE??? I HAVE MUCH TUNED ROMS(SPOON,KS)BUT THEY NOT to DECIDE MY PRABLEMSSS
Old Oct 6, 2003 | 11:18 AM
satan_srv's Avatar
Default Re: chiping prelude,help (raser5050)
without an o2 sensor I don't know if your car will function well.
People get O2 simulators for the secondary o2 sensor...but I'm not sure if that will work for a Primary o2 sensor. That way it doesn't matter becuase the simulator just sends a regular signal.
User kteller8 sells them and would know if this would work
Old Oct 6, 2003 | 11:39 AM
KTeller8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv &raquo;</TD></TR><TR><TD CLASS="quote">User kteller8 sells them and would know if this would work
o2 simulator:
This little device is piggied on to the wiring harness and will fool the ecu from thinking that the secondary 02 is reading the correct voltage. Unlike other simulators on the makert which still throw out the check engine light, EF-1 has checked and fixed all bugs.
i have this if this is what is needed:
as far as your fuel over there, i read that it is junk and that is killing your sensor: My question is what does everyone else do?
Old Oct 6, 2003 | 11:40 AM
KTeller8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racer505 &raquo;</TD></TR><TR><TD CLASS="quote">Hi people,helps me.My car prelude 93,JDM,H22A,ECU P13,NEEDED disable o2 sensor in my ECU,have who ROM EDITOR or ready ROMs? HOPE ON YOUR HELPS,SORRY ME ENGLISH </TD></TR></TABLE>
his car is : 1993 jdm h22a and is running a P13
he wants to disbale the o2 sensor
Old Oct 6, 2003 | 12:32 PM
raser5050's Avatar
Default Re: chiping prelude,help (KTeller8)
what it is,how looks??
Old Oct 6, 2003 | 12:51 PM
raser5050's Avatar
I exactly not to know that with fuel but o2 sensor be coverred by black raid as waked rich mixture,I try to adjust S AFC no good luck
I think that you little comprehensible my english
Old Oct 6, 2003 | 01:17 PM
rasser5050's Avatar
I know that be MUGEN ROMs for P28 ECU where no o2 sensor supports,I have this
,I think be and on P13 ECU
Old Oct 10, 2003 | 11:23 AM
rasser5050's Avatar
Heyyy,you have not tuned ROMs, or you not when to help???
Old Oct 10, 2003 | 01:32 PM
satan_srv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raser5050 &raquo;</TD></TR><TR><TD CLASS="quote">what it is,how looks?? </TD></TR></TABLE>
I don't think it will work, that simulator is for the secondary O2 sensor, I have no idea if you can eliminate the Primary o2...I don't think so just because the engine uses it as a parameter to make fuel adjustments..hmm let me look into it.
Old Oct 10, 2003 | 02:33 PM
rasser5050's Avatar
yes,I fight with this problem already long ago,I miserable my engine,very rich mixture slowly but faithfully kills my engine !!!!
Old Oct 10, 2003 | 05:54 PM
prospeed's Avatar
Hi i can solve this problem but only going with the Hondata system. Just need to get a p28 and a s100. Thats all you need. We have both stock H22a programs and modified h22a basemaps.
CivicExMaster
25
Oct 15, 2008 07:16 PM
Kirk@SyndromeAuto
Feb 24, 2005 03:47 PM
JDMF22B
Oct 10, 2004 03:33 PM
FoundryWorks1
Oct 2, 2004 12:19 PM
LostAndFound
18
Jun 25, 2004 10:46 PM
