97+ H22 injectors on my 95 LS OBD1
Old Sep 29, 2003 | 06:43 PM
PiNoYInTeGRa's Avatar
Default 97+ H22 injectors on my 95 LS OBD1
Hey sup guys.. still kind of new on honda-tech.. did a search nothin came up what i was lookin for.. okay just simple question.. would 97 and up prelude vtec injectors work on my 95 ls obd1 or would that not work at all? im plannin on upping my compression soon and some stage 2 crower cams.. so just lookin ahead of my options for feul injectors.. thanks..
Old Sep 29, 2003 | 06:45 PM
Banned at 5pm's Avatar
Default Re: 97+ H22 injectors on my 95 LS OBD1 (PiNoYInTeGRa)
I think 92-95 vtec might work...or you can try the 2.3 non vtec....still bigger then ls injectors i bet.
Old Sep 29, 2003 | 06:49 PM
i know the 97 + is 280 or 290cc.. not sure what the 92-95 vtec or 2.3 nonvtec not sure what size they are..
Old Sep 29, 2003 | 06:56 PM
Default Re: (PiNoYInTeGRa)
Im just thinking about the OBD I think its anywhere between 240-270...
Old Sep 29, 2003 | 07:12 PM
Newman's Avatar
New User
Default Re: 97+ H22 injectors on my 95 LS OBD1 (Hey Im Vlad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hey Im Vlad &raquo;</TD></TR><TR><TD CLASS="quote">I think 92-95 vtec might work...or you can try the 2.3 non vtec....still bigger then ls injectors i bet.</TD></TR></TABLE>
The 92-95 Prelude injectors are peak & hold (and 330cc), so they'll require a fuel injection resistor box due to the impedeance of the injectors. If you use OBD-2 Prelude (97+) injectors, then they are saturated, like your current B18 injectors, so a fuel injector resistor box will not be needed, but you'll need to modify the clip for the OBD-2 injectors so they'll plug into your OBD-1 harness. BTW, your LS injectors are 240cc and the 97+ Prelude injectors are 290cc. Not that much of a difference but still do-able.
Old Sep 29, 2003 | 08:10 PM
sweet thanks.. hmm i wonder how i could modify my clip.. i couldnt just use a 97+ injector clip on plug it onto my obd-I harness or that wouldnt work..
lude98SH
Oct 31, 2005 07:56 AM
boosted dc
Oct 8, 2004 02:06 AM
b16vtecsol
25
Mar 2, 2004 02:41 PM
YashiMotors
Jan 5, 2004 11:57 AM
CRX_VTEC
Aug 11, 2001 01:24 AM
