B16A timing
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DX2B16A(SIR) »</TD></TR><TR><TD CLASS="quote">which one does it need to be set to. to be tdc. thanks for the pic.
does it need to be set on the 16btc?</TD></TR></TABLE>
nope, for top dead center set to the 0btc
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Renegade »</TD></TR><TR><TD CLASS="quote">when timing is adjust it is set to 0TBC, what do we use the other for?</TD></TR></TABLE>
i'm not to sure but i would also like to know.
0 degrees helps set timing when doing valve adjustments, cam installations, timing belts, etc and is used to line the cam sprockets up with the bottom end to prevent hitting of pistons and valves.
When setting ignition timing with a timing light the 16 degrees is the factory set timing increment to use. I have mine at 18 which is also considered advancing the timing two degrees. The 14 degree line would be considered retarding the timing and would be used on boosted/nitrous applications in general.
From: I told you to wait in the truck in Texas, United States
The white mark is for setting the cam timing when you are setting the valves or replacing the belt..The red mark is for when you hook up the disco strobe light and set your ignition timing..two different things
P.S. the engine turns/runs "counter-clockwise" if you know what that means..
Modified by 88DXCRX at 8:38 PM 9/30/2003
1SloNeon
Jan 27, 2008 10:15 AM
phathodna35456
Jan 21, 2005 07:35 PM
