200whp- what camshafts?
im just wonderin who is using what for their 200hp ventures. formmy last thread it seemed that hardly anyone was using toda parts for this, but i need more evidence before i spend my hard earned cash on camshafts..
and could u tell me what stage cam your running too TIA
i really dont want this thread to turn into another popularity contest
we all know ef-1 > toda
it really just depends upon your whole setup. all of the cams out there can get you to 200whp
as rocket posted:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">
Airflow Path (Any weak point in this path and you'll ruin your NA power)
Intake-->TB-->Manifold-->Headwork-->Cams/springs-->Header-->No Cat-->2.5+ exhaust piping-->2.5+ straight through muffler.
1) Intake: AEM or ICEMAN
2) TB: ITR or larger
3) Manifold: ITR or better
4) Headwork: RLZ, JG, HondaSaver, Portflow, Alaniz, etc
5) Cams: ef-1, RLZ, JUN, Toda, Skunk2. Their bigger cams run at tighter lobe centers, 290+ gross duration
6) Header: DC JDM 4-1 or better
7) No cat
8) Exhaust Piping: 2.5+ Inch. Accordingly Done is nice
9) Muffler: 2.5+ inch straght thru. Apexi N1 is nice
Note:
1) The more displacement the better. The bigger the bore the more air you'll flow.
2) CP pistons are real nice and help power production
3) CR doesn't need to be sky high. 10.7 - 11.5 on pump gas is fine
4) Stock ignitiion is fine with good plugs gapped at 0.035 - 0.038"
5) SPEND MONEY ON TUNING. All motors like slightly different cam, fuel and ignition settings. Hondata is my choice here.
6) Pick an engine builder who uses a good machine shop and can properly assemble everything.</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=620298
there is your ingredient for 200whp
its not one thing, its everything that will get you there
as rocket posted:
7) No cat
Note:
as far as cam shafts?
as long as they arent total crap, if everything else is good and works together well, then you can easily hit 200whp with just about every cam you have listed in your choices
if you arent at 200whp with those cams
invest money into getting better parts that rocket listed
a few people i know around town are running the top fuel cams......they seem to work really well, my buddy has some with jg springs in a bone stock itr motor that hits 12.90 all day in his eg si.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TwistedHatch »</TD></TR><TR><TD CLASS="quote">a few people i know around town are running the top fuel cams......they seem to work really well, my buddy has some with jg springs in a bone stock itr motor that hits 12.90 all day in his eg si.....</TD></TR></TABLE>
jg valvesprings? with top fuel cams? is that what u mean?
many people with proper tuning and decent bolt ons have hit 200whp with itr cams.
epgonzalez hit 200 something hp with his stock itr cams.
i can't wait to try out ef-1 cams
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnzm »</TD></TR><TR><TD CLASS="quote">i konw this. i own skunk2 stage 1. but im curious as to what everyone else is using to get there.</TD></TR></TABLE>
I made 200 on the stage 1's
I gree with Bob- you could essentially have GSR cams, and if the rest of your parts are good- get 200 whp.... this question is goofy! I've seen people make 200 whp on B16 cams.. granted there was alot of $$ elsewhere.. but you get the idea
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by filtereds0ul »</TD></TR><TR><TD CLASS="quote">anyone reach 200whp or close with gsr cams? im thinking their not aggressive enough but then again, i can be wrong, i hope im wrong.</TD></TR></TABLE>
i guess you could do it if you have a resleeved b18c w/ 84-85 mm pistons. i mean...it'd make 200 hp because of sheer displacement, but it could make a lot more.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EVOL »</TD></TR><TR><TD CLASS="quote">
epgonzalez hit 200 something hp with his stock itr cams. </TD></TR></TABLE>
I made a little over 200whp on itr cams, on a stock b18c5 block.
Modified by All Motor Rex at 10:07 AM 9/30/2003
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by All Motor Rex »</TD></TR><TR><TD CLASS="quote">
I made a little over 200whp on itr cams, and a stock b18c5 block.</TD></TR></TABLE>
i gotta see this
i gotta see this
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drag R »</TD></TR><TR><TD CLASS="quote">i gotta see this</TD></TR></TABLE>
It was my old set up. Stock b18c5 block, DPR ported & polished GSR head, skunk 2 mani, itr cams, JDM itr header. VAFC, cam gears and fpr for tuning. Tuned at Dynamic in OC. It was a fairly simple set up and ran great.
i understand that the other mods (headwork, bore/stroke) make a more serious impact on the WHP, but im more curious about what cams the people who can eve get to 200 whp are using.
dragR- ive seen 201whp on a stock b16 bottom end with skunk2 stage 1. 200whp on a b18c5 block isint hard.
It was my old set up. Stock b18c5 block, DPR ported & polished GSR head, skunk 2 mani, itr cams, JDM itr header. VAFC, cam gears and fpr for tuning. Tuned at Dynamic in OC. It was a fairly simple set up and ran great.</TD></TR></TABLE>
thats just a little hard for me to swallow...more power to ya though man
SK2S1, toda A, and i bet u can get 200whp with ctr cams if u have a real sixk setup..like SMS header/exhaust..and about 12:1 comp w/ hondata..and a real good tuner can anyone post some dyno plots using EF-1 cams..i havent seen any good results
ttt- looks like the majority of people are using skunk2 cams to make the power, im assuming stage2's
ill be trying with a stage 1 and hope to hit 200whp. does anyone know what kinda gains i might see going from a stage1 cam to a stage2 cam and nothing else change but tuning?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnzm »</TD></TR><TR><TD CLASS="quote">ttt- looks like the majority of people are using skunk2 cams to make the power, im assuming stage2's
ill be trying with a stage 1 and hope to hit 200whp. does anyone know what kinda gains i might see going from a stage1 cam to a stage2 cam and nothing else change but tuning?</TD></TR></TABLE>
if u r not changin anything...u can def hit 200 whp with stage 1's just havea sick header & exhaust combo...basically u r gonna have to come out of ur pocket...if u have doe and can wait..get either SMSP/hytech/DTR/Toda..those r some good headers.. and even one of their exhaust systmes...hondata some and anything that can help u gain compression like a mugen headgasket...and cam gears..most important a good tuner!!
