skunk2 stage 2, with minimal gain
Old Sep 29, 2003 | 02:36 PM
notsure's Avatar
Default skunk2 stage 2, with minimal gain
Right now I am running an ls/vtec (gsr head) with all the boltons, gsr pistons, stock rods and crank, skunk valvetrain (with stage 2s). Right now i am running about 10.6:1 cr, maybe a little higher due to a milled head. when i first drove the car i definitly noticed a little more lowend, and a lot more highend (7K on pulls like a fiend) but i am plagued with the low redline of the ls. but i would think that the stage 2s, even untuned would make me a little faster. but i am still getting beat in the high end by my roomates lude si (with jdm h22a swap i/e only) and he doesnt beat my by a little, he flew by me at the top of third.
2 questions:
-what cr should i be at to really take advantage of the s2 stage 2? i heard its high but never a solid number. i have pr3 pistons under my bed, that would give me like 11.7:1
-is there anything that i can do (adjusting cams) myself before i can tune my car? i have adjustable cam gears (intake is +1 exhaust 0)
any help would be greatly appreiciated, jdm lude must die
Old Sep 29, 2003 | 02:51 PM
1fasthb's Avatar
Default Re: skunk2 stage 2, with minimal gain (notsure)
i have stock jdm itr cr and they work just fine.
you really need to get the redline higher to really notice the power.
Old Sep 29, 2003 | 03:36 PM
notsure's Avatar
Default Re: skunk2 stage 2, with minimal gain (1fasthb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1fasthb &raquo;</TD></TR><TR><TD CLASS="quote">i have stock jdm itr cr and they work just fine.
you really need to get the redline higher to really notice the power.</TD></TR></TABLE>
thats for damn sure, i have been researching that quite a bit. the latest that i could find was to keep my stroke, but to use the longer B20 rods to give me a better r/s ratio.
do you have your r tuned, if so how much of a difference did it make?
does anyone have any experience with using b20 rods in an ls/vtec? what crank would i use? bearing?
Old Sep 29, 2003 | 03:44 PM
1fasthb's Avatar
no i didnt tune it yet, im wating on some parts still
Old Sep 29, 2003 | 06:43 PM
notsure's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1fasthb &raquo;</TD></TR><TR><TD CLASS="quote">no i didnt tune it yet, im wating on some parts still</TD></TR></TABLE>
oh yeah its in the sig... btw congrats on the dyno comp. those are some pretty good numbers for your setup.
Old Sep 29, 2003 | 07:14 PM
Mach30SiR's Avatar
Some one please help him out, its ruining our friendship
-JDM Lude
Old Sep 29, 2003 | 07:21 PM
92 civic VX B18c's Avatar
HT Black Ops
Default Re: skunk2 stage 2, with minimal gain (Mach30SiR)
hmm, well tuning will almost certainly get you more power..
I have Skunk2 stage2's in my car and I noticed a huge gain over 6krpms and lots of new low end power that wasn't there before... I don't know what kind of # they made for me, because my clutch went out the next day after installing them!#^%@$#^$!^^!#%!@!@#$....
But this thursday I will be getting a new clutch, and trying for some more butt dynoing while ajusting the fuel settings and vtec crossover... I don't want to mess with actual cam timing untill I am on the dyno machine.. I'll keep you posted
Old Sep 29, 2003 | 09:15 PM
91integraLSVTEC's Avatar
Default Re: skunk2 stage 2, with minimal gain (92 civic VX B18c)
after installing my skunk stage 2s for the first time i was very dissapointed.. but after a good a header and some tunning on the dyno i fell in luv on how they pulled in the upper rpms.. stage 2's are not drop in cams, and even while tunning there harder to tune than jun cams.. but worth every penny spent
Old Sep 29, 2003 | 09:54 PM
racerboyb18c1's Avatar
Default Re: skunk2 stage 2, with minimal gain (91integraLSVTEC)
most likely need more compression and do u have port work done? if not some good undercut valves and seat work and bowl work will help those cams breath , i suggest getting hondata and tunning also are u runnin a stock ls bottom with ls pump? if so get a gsr oil pump if u want to keep ur motor
Old Sep 30, 2003 | 03:17 AM
function83's Avatar
Default Re: skunk2 stage 2, with minimal gain (racerboyb18c1)
b20 rods are the same as ls rods.
so swappin them wont do you any good.
your problem is not having enough compression for high lift cams
and not revin high enough.
i suggest rebuilding your block with some b16 pistons, z10 block girdle, vtec oil and water pump, balanced bottom end with arp rod bolts.
then you shall rev up safely to 8 grand or higher with proper valvetrain.
Old Oct 24, 2003 | 07:30 PM
spunky424's Avatar
i jus got skunk2 stage 2 cams jus today and had them installed also...valves are ticking, so i will have to do a valve job tommorrow...but they seem to pull okay...i dont have money for tuning right now but i jus wanted to know if it will beokay to ride on without tuning them for a while? my valve train is built so jus wondering if it will be okay.
Old Oct 24, 2003 | 10:04 PM
ZigenBallz's Avatar
Default BLAH
What tranny are you running notsure? The LS tranny? I would assume that the non vtec LS tranny would have longer gears not really suited for staying in VTEC... that might have something to do with your topend... H22 gears are short too...
I don't keep up on the DOHC specifics though... just trying to help...
Old Oct 24, 2003 | 10:44 PM
TyPe_R_GuY's Avatar
i have the skunk2 stage 2 cams in my R, with stock block and stock compression, making 201.3 whp and 138 trq. power mods, Cams, CAI, Test Pipe and Exhuast, along with P28 ECU, VAFC and FPR and Gauge, TUNED, hope that helps you on your troubles a little
Old Oct 25, 2003 | 06:54 AM
quikyEG's Avatar
Default Re: (TyPe_R_GuY)
to use the skunk2 cams i would run nothing less than atleast 11.5cr, if you plan on staying the way you are just get the stage 1's. without tuning dont plan on getting big gains with cams, i have stage 2 cams also, and my base run was like 168 or something, now i have 195tuned. on yeah and im running 11.5cr. with cams tuning is the key
Old Oct 25, 2003 | 07:22 AM
Hybrid-B's Avatar
Default Re: (quikyEG)
yea definitely 11.5 or up, i have stage 2s in my setup and im running 12.5:1 cr and good tuning, i can really feel the power gains from them.
Old Oct 25, 2003 | 08:05 AM
fastciviccoupe's Avatar
Type R Guy is your head stock? bcuz i have a stock itr head and i was wondering if i can use some stage 2's with my stock itr valve train.
Old Oct 25, 2003 | 09:39 AM
SiR831's Avatar
Default suggestions
Running a JDM GSR with bolt on's (see sig for time). And i was wondering if head work, valve train, and skunk2 stage 2 cams will net me in the 12's with a stock block. Of course with Hondata and tunning. Long story short will the stock JDM GSR pistons be sufficient enough for the the Skunk2 stage cams? Thanks
Old Nov 1, 2003 | 07:13 AM
quikyEG's Avatar
Default Re: suggestions (SiR831)
i wouldnt get stage 2's with gsr pistons, upgrade to jdm integ type r's and a slightly milled head, thats what i got, it runs great and reliable.
Old Aug 5, 2004 | 07:45 AM
vntperformance's Avatar
What does every one with S2S2 Cams have there cam gears set on?
vnt
Old Aug 5, 2004 | 08:37 AM
notsure's Avatar
Default Re: skunk2 stage 2, with minimal gain (vntperformance)
i thought this thread looked familiar. i wish i still had that car, time to move on. thanks for all the replies
Old Apr 6, 2007 | 10:18 AM
lunatics209's Avatar
ok. here is what you should do. go with some ctr pistons. a PRO-FAB tri-Y race header. you will be a god on the streets. also tune that car too. thats the main thing you need to do especially with big cams. what kind of manifold and throttle body are you running too? i broke 192 horse and 132 torque with stock block and head. ls-vtec tuned.
Old Apr 6, 2007 | 10:58 AM
IntegraType-R's Avatar
Default Re: skunk2 stage 2, with minimal gain (lunatics209)
lol with crane stage 2's i made 186whp, with the s2s2's on the crane stage 2 tune, i made 198..thats a pretty big gain untuned.. btw..the car STOPPED making power around 8600rpms..but it didn't flaten out until about 9 you really need to rev these cams to almost 9 grand to see the full effect..
My motor is well, far from stock, still a stock block but the CR is around 11.8, which is ideal for these cams.. their not small and require good bolt ons and head work to see the full effect.
As for cam timing, i haven't fully tuned the gears out, but so far i'm +4 on the intake, 0 on the exhaust.. and the car is wicked on top end..and still keeps the low end power.. my vtec is set at 5700rpms..and well its a very quick car..i'm installing itbs on it as we speak..so ya..i'm shooting for deep into the 220whp range.
Old Jun 3, 2007 | 11:50 PM
mike_paz17's Avatar
yall didnt pay attention did you? this thread is 3 years old!
Old Jun 4, 2007 | 03:45 AM
Jay_Sensing's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lunatics209 &raquo;</TD></TR><TR><TD CLASS="quote"> you will be a god on the streets. </TD></TR></TABLE>
LMFAO. These are great.
Old Jun 4, 2007 | 07:10 AM
2fastGSR's Avatar
King of the One Liners
Default Re: skunk2 stage 2, with minimal gain (mike_paz17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike_paz17 &raquo;</TD></TR><TR><TD CLASS="quote">yall didnt pay attention did you? this thread is 3 years old! </TD></TR></TABLE>
see what had happened was 3 years ago he was still a freshman in high school he saw this thread, now he replied cause he finally got a 99 Si with VTEC YOOOOOO
Dom93
Jan 23, 2012 12:53 PM
IggyBcool
16
May 14, 2005 05:57 PM
JinteDgraM
Mar 20, 2005 09:06 PM
orca
May 11, 2004 07:29 AM
toooslow
Mar 18, 2004 04:36 PM
