Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
KYB AGX setup for auto x
Old Sep 29, 2003 | 01:47 PM
oneslodx's Avatar
Default KYB AGX setup for auto x
hey everyone, i raced my first auto cross the other day and im running KYB AGXs with H&R springs, i had all four corners set at 4 which is the stiffest, im just wondering wat you guys set it at, this is in a 95 civic coupe with b18c swap and yoko avs es 100s on 15s. i was having a good amount of traction issues in the turns, did i have the shocks too stiff?
Old Sep 29, 2003 | 02:23 PM
.RJ's Avatar
.RJ
Default Re: KYB AGX setup for auto x (oneslodx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oneslodx &raquo;</TD></TR><TR><TD CLASS="quote">i was having a good amount of traction issues in the turns, did i have the shocks too stiff? </TD></TR></TABLE>
I think you had your velocitator too stiff.
Old Sep 29, 2003 | 03:02 PM
CRX Lee's Avatar
Next time try softening the front to 2 or 3. Softening them should reduce some chances of unloading front tires and also help the car rotate.
Old Sep 29, 2003 | 10:40 PM
MrIllegalX's Avatar
I have agx's and I didn't like the way it handled when I had it on full stiffness. Mine goes from 1-4 in the front and 1-8 in the rear though. It was really too stiff IMO.
So far I like it when the front is on 3 or 4 and the rear is at 6. I'll mess around with it more when I do some time only runs, don't wanna ruin a timed run because of stiffness!
Old Sep 29, 2003 | 11:23 PM
ConeS's Avatar
Default Re: (MrIllegalX)
I run em around 1f/2r or 1f/3r.
Old Sep 30, 2003 | 05:25 AM
hatchblack's Avatar
since no one else is asking, what kind of traction problems are you having? don't go messing around with changing the front and rear stiffness until you tell us how it is reacting. perhaps you just need to change your tire pressures. that can make a big difference too. does your car plow, or is the back end really loose? give us a little more info please.
Old Sep 30, 2003 | 06:42 AM
ZUL8R's Avatar
Default Re: KYB AGX setup for auto x (hatchblack)
3F 6R with GC's.... been that way since we installed them a few months back.. I have no complaints on the way the car handles. we run Victoracers with 39F 39R.
Old Sep 30, 2003 | 07:36 AM
WRXRacer111's Avatar
Default Re: KYB AGX setup for auto x (ZUL8R)
'95 Integra RS, H&R OE-Sport, 26mm front bar, 22mm rear bar, 215/40/16 Kumho 712s @ 45f/39r psi...
KYB AGXs @ 3f/4r, 2f/4r on tight courses.
Old Sep 30, 2003 | 11:44 AM
kahlua2323's Avatar
00' GSR, Eibach sportlines, 22mm rear bar, 205/50/15 falken azena's, 40f/38r psi..that varies tho... kyb agx's @ 4f and 1r for autoX...road track 1f and 4r
Old Sep 30, 2003 | 01:56 PM
Mike_C's Avatar
I recently had mine at 3f/4r with a lot of push occuring. I'm thinking 2f/4r might be the way to go for a starting point.
Old Sep 30, 2003 | 04:04 PM
maxim's Avatar
Default Re: (JMU1337)
I have a 00 coupe and run max in the front(4 for mine) and 5(out of 8 settings) in the rear. Of course, I also ride on Azenis and have a 22mm sway as well. I also tend to drive a bit more agressive than others, which caused my car to rotate too much when leaving the rear stiffer and the front softer (or 2f/6-8r)
Old Sep 30, 2003 | 05:35 PM
oneslodx's Avatar
hey the problem i was having was the front end would slide to the outside of turns, i had the backend get loose a couple times but thats just because my noob self went into a turn way to fast, thanx for all the advice from everyone, theres another autocross on the 19th so im gunna try to change it some for that
Old Sep 30, 2003 | 06:27 PM
CRX Lee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oneslodx &raquo;</TD></TR><TR><TD CLASS="quote"> the problem i was having was the front end would slide to the outside of turns </TD></TR></TABLE>
Understeer. Sounds like concensus says soften the front
some and this should go away.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oneslodx &raquo;</TD></TR><TR><TD CLASS="quote"> i had the backend get loose a couple times but thats just because my noob self went into a turn way to fast</TD></TR></TABLE>
Oversteer. This time admittedly driver induced so make him stop overdriving. Keep the current adjustment until you get the front sorted out.
Old Sep 30, 2003 | 07:34 PM
Autoxjoe's Avatar
Default Re: KYB AGX setup for auto x (CRX Lee)
your suspension is probably bottoming out causing the understeer
i feel that my kybs are slightly underdampened and leave them at full stiff
ehmarc
Jun 25, 2007 12:47 PM
EJ1EG
May 18, 2006 03:34 PM
CHONCH
Oct 17, 2005 12:11 AM
Loil
Aug 11, 2004 08:28 PM
N~FaMouSKhMerBoi
52
May 17, 2004 09:04 AM
