need info on weights.......
basically 2320lbs vs 2615, but once you swap all the hardware, IE. rear discs, bigger brakes, 15" wheels, b-series swap, sway bars you will add another 120-175lbs, which is still about 150lbs less then the si/sir coupe
92
DX Sedan EX Sedan LX Sedan
Automatic (lb.) 2343 2524 2388
Manual (lb.) 2275 2480 2319
2000
DX Coupe EX Coupe EX with ABS HX Coupe Si Coupe
Automatic (lb.) 2405 2560 No Data 2445 No Data
Manual (lb.) 2359 2513 No Data 2370 2612
92
2000
JPerkMr954
30
May 30, 2011 08:30 PM
pliskin679
Honda Civic (2006 - 2015)
11
Nov 12, 2007 07:33 AM
