what kind of gas should i put in my 95 accord lx
Old Sep 29, 2003 | 07:34 AM
HONDAMIKE69's Avatar
Default what kind of gas should i put in my 95 accord lx
right now im puttin 89 is this right it has 90000 mile s now tnx
Old Sep 29, 2003 | 08:20 AM
sauceman's Avatar
Default Re: what kind of gas should i put in my 95 accord lx (HONDAMIKE69)
You don't need to. 87 will do just fine.
Old Sep 29, 2003 | 09:39 AM
iam7head's Avatar
Default Re: what kind of gas should i put in my 95 accord lx (sauceman)
87, just run the grade of gasoline your car is design to run.
no more no less
Old Sep 29, 2003 | 09:12 PM
accordfreak's Avatar
Default Re: what kind of gas should i put in my 95 accord lx (iam7head)
i run 91 octane with 3 gallons of 100 octane
Old Sep 29, 2003 | 09:19 PM
iam7head's Avatar
Default Re: what kind of gas should i put in my 95 accord lx (accordfreak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordfreak &raquo;</TD></TR><TR><TD CLASS="quote">i run 91 octane with 3 gallons of 100 octane </TD></TR></TABLE>
turd-blow huh?!
Old Sep 29, 2003 | 09:23 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head &raquo;</TD></TR><TR><TD CLASS="quote">
turd-blow huh?!</TD></TR></TABLE>
hmm i think so.. it's kinda what you have..
Old Sep 29, 2003 | 11:13 PM
H22SiRaccord's Avatar
No reason to run higher than 87 unless you are running forced induction or a built up motor. If you are still stock than just stick with 87 and you will do just fine.
Modified by H22SiRaccord at 3:15 PM 9/30/2003
Old Sep 29, 2003 | 11:49 PM
NA gs-R 05 C
Guest
Posts: n/a
if you still have the accord motor, then 87, 89 is cool.
Old Sep 30, 2003 | 09:20 AM
acc97lxAndy's Avatar
and what happen is u used 93, is still the same for the engine
Old Sep 30, 2003 | 09:37 AM
sauceman's Avatar
Default Re: (acc97lxAndy)
I found that on my 95 EX, with 94, the car was actually less powerful, and at the track, I was doing worst times than when I had 87.
Old Sep 30, 2003 | 11:08 AM
pisces21's Avatar
Default Re: (sauceman)
there was an article and study done where most times you should use the recommended octane for ur car. anythign less or more makes the car run slower. I'll try to find the article. 87 octane sounds about right for your car. i used to have a 94 (same gen) and i ran with 87. Unless of course as someone pointed out, u have forced induction.
Old Sep 30, 2003 | 11:09 AM
Sarwat's Avatar
87 octane burns easily and therefore more completely than say 92 octane when comparing the stock ignition system, timing etc.
On a stock car/ignition you will generate more carbon with higher octane so it will do more harm than good. Stick with 87 octane...unless your car is modified then its a whole different topic.
Old Sep 30, 2003 | 12:18 PM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acc97lxAndy &raquo;</TD></TR><TR><TD CLASS="quote">and what happen is u used 93, is still the same for the engine
NO, the fuel actually burn slower, the well known low compression accord motor will have hard time burning 100% of the gas, the quach-area will form carbon after number of year(depends on condition of the motor).
carbon is the black tar **** inside your motor.
if your piston head got enough of the carbon, it will start a good old two flame fronts on a hot summer day(going uphill, a/c on and the engine melt/break stuff inside)
nota-ex
104
Jun 13, 2010 10:48 AM
5thGeneration
Nov 2, 2007 07:02 AM
pnut1.8c1
117
Apr 23, 2007 10:27 AM
vietkangta
May 5, 2006 08:30 PM
BLK99VTECR
Aug 24, 2003 10:04 PM
