Koni sport (yellow) perches
If i buy koni sport shocks and i put Neuspeed race springs or other springs that lower the car about 2", and i set them on the highest perch. then how much would they lower my car?
well if you can figure out which one is the oe perch height, then just measure the distance from that perch to the highest perch. Subtract that length from 2" and you should have your answer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000GSR »</TD></TR><TR><TD CLASS="quote">With neuspeed race spring, use the middle(stock) perch on the koni yellows. If you set it to the highest perch it will look gay.</TD></TR></TABLE>
HAHA
HAHA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -R- »</TD></TR><TR><TD CLASS="quote">If i buy koni sport shocks and i put Neuspeed race springs or other springs that lower the car about 2", and i set them on the highest perch. then how much would they lower my car?</TD></TR></TABLE>
My friend set his Neuspeed Konis on the top perch w/ his Neuspeed race springs, mainly to keep the Azenis tires from rubbing, but the drop looks perfect.
The top perch should be stock height for the front, and the middle perch is stock in back. The top perch in back should be about 15mm (5/8") higher than stock.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -R- »</TD></TR><TR><TD CLASS="quote">cuz i want the higher spring rate of the neuspeed race springs but i don't want to have a 2" drop, i want mo like a 1.5" drop</TD></TR></TABLE>
So get Koni-specific Ground Controls w/ custom rates so you can get the drop exactly where you want it. The Koni perches by themselves don't go higher than stock on the front shocks.
the soL that could
Suspension & Brakes
10
Feb 21, 2006 10:17 PM
hi-Powered
Suspension & Brakes
Dec 29, 2005 12:01 AM
