DC2 ITR and Eibach springs
Old Sep 29, 2003 | 12:42 AM
olda's Avatar
Default DC2 ITR and Eibach springs
Just bought DC2 ITR and would like to fit Eibach PRO KIT or SPORTLINE springs.
Had previously VTiR Teg (GSR in US) fitted with Eibach PRO KIT springs.
The car has "dropped" by 30mm (1.25") and handling was great.
What should I expect if I do the same to ITR ?
Anyone with experience? Thank's
Old Sep 29, 2003 | 03:04 AM
Inti#539's Avatar
Default Re: DC2 ITR and Eibach springs (olda)
Hello,
i´ve got the ITR with Eibach springs!
The car goes down for ca. 30mm and it is a little bit harder then the original springs.
I´am satisfied with the spring, for me is it ok!
But if you run races is it better to by a complete Kit...
Old Sep 29, 2003 | 09:02 AM
Opie's Avatar
Default Re: DC2 ITR and Eibach springs (Inti#539)
I ordered sportlines for my car, and sent them back, far to soft to be an improvement over stock and will blow your shocks. Try H&R sports, I have a few friends who run them in their ITR's they're happy, but they drag race. No experience on the eibach's track performance.
Old Sep 29, 2003 | 10:39 AM
jaa1311's Avatar
whats up man, sportlines came on my car when i bought it. they r preety good but there was a bit of understeer on the track when i went. they are good for daily driver though, car does sit about 1in lower than stock, not sure exactly.
Old Sep 30, 2003 | 03:25 AM
olda's Avatar
Hi there,
Thanks for the info.
Which Eibach springs have u got? PRO-KIT or SPORTLINE?
What do u mean by "a complete kit"?
I do only sprints. 3 laps against the stopwatch.
Maybe 5-6 times a year.
00 CW ITR
Modified by olda at 12:47 PM 9/30/2003
Old Sep 30, 2003 | 03:44 AM
olda's Avatar
Default Re: DC2 ITR and Eibach springs (opie112)
"SPORTLINES" far too soft? This worries me a lot!
I had PRO-KIT springs on my GSR and they felt plenty stiff.
"SPORTLINES" suppose to be stiffer than PRO-KIT springs.
Thanks for the info anyway.
00 CW ITR
Old Sep 30, 2003 | 04:07 AM
olda's Avatar
Default Re: DC2 ITR and Eibach springs (jaa1311)
I believe that the OEM set up's the best compromise for the road & the track.
However, for the "looks" sake, the car needs to be lowered.
SPORTLINES, according to Eibach, should lower the car by 1.7" (43mm).
Did you try stock springs at the same race track?
I'm glad, that you did not find them too harsh as a daily driver.
Thanks for the info!
_________
00 CW ITR
Old Sep 30, 2003 | 04:20 AM
jond's Avatar
From what I've heard, many aftermarket setups make you're car not handle as well as stock. I suggest you do some research before buying sportlines of the prokit for a ITR.
You should probably be looking more towards spoon springs, Ground Controls w/ 500F400R, or mugen lowdowns.
Old Oct 13, 2003 | 01:53 AM
olda's Avatar
Still waiting for an answer. PRO KIT or SPORTLINE springs on your ITR?
Old Oct 13, 2003 | 06:05 AM
ZygSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by olda &raquo;</TD></TR><TR><TD CLASS="quote">Still waiting for an answer. PRO KIT or SPORTLINE springs on your ITR?
I've had the H&R springs on my ITR with the stock shocks and it worked nicely, especially at higher speeds (hehe) on the highway since it kept the car from bouncing as much, esp in the rear.
No personal experience with the Eibach springs except on my CRX.
Wazup
Suspension & Brakes
Mar 9, 2005 11:39 AM
slammed00si
11
Apr 17, 2004 01:11 PM
TeGGY_LS
Mar 30, 2004 11:19 AM
Ibuprofen
May 12, 2002 04:53 PM
