staging brake vs line lock
Old Sep 28, 2003 | 08:01 PM
dmotoguy's Avatar
Default staging brake vs line lock
ive noticed that most of the drag cars i have seen have staging brakes, and i think thats what im gonna use too, but my dad thinks i should install a line lock. they are both about the same price, but i dont see many imports with line locks. are there any differences in the two, if so which one would you pick and why
Old Sep 28, 2003 | 08:56 PM
saso
Guest
Posts: n/a
Default Re: staging brake vs line lock (dmotoguy)
I have a line lock but I dont use it. I believe its used for burnouts or to prevent rolling on the line.
Old Sep 29, 2003 | 07:11 AM
dmotoguy's Avatar
Default Re: staging brake vs line lock (jerseykid609)
thats exactly what i had told him, thanks for the help guys
Old Sep 29, 2003 | 08:14 AM
CHEETAH's Avatar
they both do the same thing, difference is linelock needs pressure to be applied in order to lock brakes, the staging brake is easier in that you manually lock brakes then gradually release to now drag (rear) wheels towards end of burnout.
Linelock comes in handy at the launch in that you can lock rear brakes with a switch on the steering wheel, etc. and let go when you launch as opposed to realease stagebrake manually ...
i have both in my racecar anyway.
Greg
Old Sep 29, 2003 | 09:07 AM
ninesecrx's Avatar
Default Re: staging brake vs line lock (CHEETAH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CHEETAH &raquo;</TD></TR><TR><TD CLASS="quote">they both do the same thing, difference is linelock needs pressure to be applied in order to lock brakes, the staging brake is easier in that you manually lock brakes then gradually release to now drag (rear) wheels towards end of burnout.
Greg</TD></TR></TABLE>
If it were me, id put the line lock on the front wheels so you have no chance of breaking the beams at the line and its easier to load the clutch up. I am also in favor of just the staging brake if you do just 1 thing because you can appy brakeing pressure with just the right hand which really helps with burnouts and stagging of the car.
Old Sep 29, 2003 | 09:13 AM
pro1342's Avatar
I like the staging brake for the fact that you can on/off the brake easier.
Old Sep 30, 2003 | 07:28 AM
dragsol's Avatar
Default Re: (pro1342)
where is a good place to get staging brakes. thanks. What is into the instalation.
Old Sep 30, 2003 | 07:58 AM
pro1342's Avatar
Default Re: (dragsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragsol &raquo;</TD></TR><TR><TD CLASS="quote">where is a good place to get staging brakes. thanks. What is into the instalation.</TD></TR></TABLE>
Search on yahoo or something for CNC staging brake or cutting brake. You usually end up at a VW/dune buggy site. You're gonna need lines for the install.
Old Sep 30, 2003 | 09:03 AM
earl's Avatar
The trick for installing it is to isolate it to both rear brakes. Your foot operates the front brakes and your hand operates the rear brakes.
Old Sep 30, 2003 | 05:48 PM
99blackcivicSi's Avatar
Default Re: (earl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">The trick for installing it is to isolate it to both rear brakes. Your foot operates the front brakes and your hand operates the rear brakes.
I was just about to say that you beat me to the pounch for you
Old Sep 30, 2003 | 06:36 PM
saso
Guest
Posts: n/a
Default Re: (99blackcivicSi)
i dont use the line lock cause at the line its too much to think of. I have to press 2 step, then line lock button then pump brake then watch light blah
Old Oct 2, 2003 | 04:06 PM
speedworks's Avatar
Default Re: (saso)
saso is right. when running a pro tree it is almost impossible to get it locked before the tree comes down, especially when the other guy is already staged.
Old Oct 2, 2003 | 04:44 PM
dmotoguy's Avatar
Default Re: (speedworks)
thats what i was thinkin too.. staging brake for me...
K20EF8Dx
Jun 17, 2013 05:04 PM
JBLAZE622
Dec 31, 2008 06:02 PM
karmadhi
Apr 26, 2008 06:32 PM
AlphaKennyWun
Feb 26, 2002 03:11 PM
