Which Drive shaft do I need for a B16hatch?
Ok guys, I believe I messed up my drive shaft because of hammering too much due to the axel not coming out from rust... So anyways I have a b16 in a 91 hatch with a J1 tranny, I just changed the axels, and it's making noise from the bearing of the drive shaft. I am headed to the junk yard for another drive shaft but not sure which drive shaft I should look for... Let me know which one i need guys! I believe its the 90-91 driveshaft, but I want to be sure..
are you talking about the mid shaft.. it should be a 90-93 integra.. or a 94+ integra.. look at your driverside axle.. is it a male or female? if male than 90-93, if female 94+.
HTH
HTH
dude dont be picky with the name, soem call it half shaft, mid shaft, intermediate shaft. but if your runnin 90-93 teg axles and they arent binding or anything, u probably have a 90-93 half shaft
Ok I dont know what i need now... On the driver side... There is an axel that is about 1-2 feet long that I had to pop out of "xxx thing" that "xxx thing" goes into the tranny...I need that "xxx thing" replaced because the bearing on that thing is messed up and i thought it was called a drive shaft... So what is it called and which part do I need it for so I can replace my part on a b16 j1 tranny.
wasanissanFL
Transmission & Drivetrain
Feb 4, 2016 01:37 PM
biassj
May 16, 2003 03:57 AM
