dc5-r pistons on ep??
all k20 motors are 86x86 so i would say it would bump your compression a good amount, i wont toss any numbers out there because i have no idea of the stock compression on either. but its the same idea of using DC2-R pistons on a b16a
thanks dude.. cause i, picking up a type s head.. and im guessing.. using the head and dc5-r pistons... will raise my compression a lot... so if it is possible ill buy them... thanks
edit: stock compression is 9:8:1..
Skunk2 replaced the k20a3 9.8:1 pistons with the ITR 11.5:1 pistons. They are interchangable. Direct swap. All you would need are the pistons, rings, wrist pins and clips for the pins.
BTW, how much are you selling those new pistons for?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by epthree »</TD></TR><TR><TD CLASS="quote">Skunk2 replaced the k20a3 9.8:1 pistons with the ITR 11.5:1 pistons.</TD></TR></TABLE>
woo hoo, i was right.
maybe my brain isn't as shot as I thought it was.
why not shave the head a few thousants? and add a spoon head gasket...thats about 12.5 or so compression. would be about the same price, correct me if i am wrong..the only thing in the way would be the valve to piston clearance ( which would only be a factor if you screwed with the timing)???
