2 Questions for ya'll
Old Aug 26, 2001 | 02:12 AM
khand187's Avatar
New User
Default 2 Questions for ya'll
First one -- Just got a Tanabe RM exhaust system. It came w/ a white tube of grease. What do I apply this to and why?
Next one -- Just recently I'm finding it hard to shift into any gear. At idle, everything shifts nice and smooth. While driving, I really gotta apply force to get 'er in gear. There are no noisees or smells, btw.
Any help would be appreciated. Thanks alot.
Old Aug 26, 2001 | 02:38 AM
OneThirtyEight's Avatar
Default Re: 2 Questions for ya'll (khand187)
for #1 it sounds like an anit-sieze compound you are sopposed to use on the bolts so they come off easy in the future. for # 2 sounds like your clutch is going or needs to be adjusted.
Old Aug 26, 2001 | 06:03 AM
khand187's Avatar
New User
Default Re: 2 Questions for ya'll (97blackteg)
Thanks blackteg.
How do I go about adjusting the clutch?
Thanks again.
Old Aug 26, 2001 | 07:28 AM
Variance-EJ-6's Avatar
New User
Clutch cable...play with it - bolt that turns clockwise and counter - , not to tight though.....otherwise you will burn clutch....
Old Aug 26, 2001 | 10:29 AM
Rory Breaker's Avatar
#1 sounds like the wax they give you for the muffler...
Old Aug 26, 2001 | 11:09 AM
MintyDip's Avatar
I have this problem too.
after i installed my header, cat, exhuast i found it harder to shift. i mis shift more now too
Old Aug 26, 2001 | 05:24 PM
khand187's Avatar
New User
Default Re: 2 Questions for ya'll (Vengeance-DA9)
So, you're sayin try to adjust the cable and shat. That might do the trick?
Old Aug 26, 2001 | 05:29 PM
slowerthanu's Avatar
New User
Well he is, but unfortunately the DC2 doesnt come with a cable clutch, it is hydraulic. You may want to bleed the hydraulic system and check your play on the pedal and at the clutch fork. If you dont know what I am talking about, take it to the dealer.
Old Aug 27, 2001 | 02:19 AM
keys's Avatar
Default Re: 2 Questions for ya'll (slowerthanu)
true true, only gen2 integras have cable trannies...... gen3 integras are all hydrolic and have no cable to adjust
Kentagious
Jun 29, 2006 02:04 PM
Hebrew-Hammer
Mar 24, 2005 04:08 PM
_Endless_
Sep 4, 2004 02:46 AM
petrv
Aug 17, 2004 02:10 AM
sinfulDB1
May 5, 2003 09:26 AM
