Wiper Problem
My wipers are messed up on my 93 DX HB. The wipers only work on low. Intermediate and High don't work. Low is the only setting that works, but when you push down and mist than they work too. Are the high and low wipers on a seperate fuse than the intermediate ?
Probably a switch went bad at the base of the control stalk. You'll probably have to remove that to check it. Go to a bookstore like Borders and browse the Chilton's. You have to remove the steering column cover and unscrew I think 4 screws before you pull out the control stalk assembly.
hardtarget2
14
Nov 9, 2015 10:56 AM
