CEL throwing Map Sensor and Fuel Injectors code
Old Aug 26, 2001 | 12:44 AM
Turbohatch's Avatar
New User
Default CEL throwing Map Sensor and Fuel Injectors code
im boosting only 8 pounds on a b16 with apexi v-afc. The cel comes on at high rpm's and engine goes into "limp" mode. Whats the problem ? need bigger injectors? or something else.
[Modified by Turbohatch, 9:44 AM 8/26/2001]
Old Aug 26, 2001 | 04:27 AM
fixhondas's Avatar
Default Re: CEL throwing Map Sensor and Fuel Injectors code (Turbohatch)
It probably has something to do with your Apexi. Sometimes they aren't very good at "fooling" the honda ecu.
Old Aug 27, 2001 | 07:31 AM
coquinn's Avatar
You may want to check this out, it could be one of the contributing factors to your problem:
http://www.hondata.com/3barinstall.html
You might want to put your APEX'i V-AFC on Sensor Check mode ...check to see how much voltage the MAP Sensor is actually getting ...best of luck.
[Modified by coquinn, 11:35 AM 8/27/2001]
Old Aug 27, 2001 | 11:10 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: CEL throwing Map Sensor and Fuel Injectors code (coquinn)
Stoopid question...........
What's the codes?
spettinger
May 27, 2008 02:21 PM
gutted
Oct 9, 2004 08:01 PM
citrus3000psi
Oct 21, 2003 03:50 PM
Mugen Mike
Jun 19, 2003 09:19 AM
Turbohatch
Aug 26, 2001 11:48 AM
