? about headgaskets and copper spray. How much will it thicken the gasket?
Old Sep 28, 2003 | 12:43 PM
Boostfed's Avatar
New User
Default ? about headgaskets and copper spray. How much will it thicken the gasket?
As the title says, what are your GUESSES or anybody calcualted how much copperspray thickens the gasket say 4 good coats? Just curiosity and I know noone has ever posted this before at least for gasket thickness. HMMM? I am thinking my .43" Cometic HP might be about .050" or so now just a GUESS.
Old Sep 28, 2003 | 12:56 PM
inspyral's Avatar
I would also guess a couple thousanths at most. You have to remember that the copper spray does get kinda squished out when the head is torqued down, so the spray itself shouldn't add too much thickness to your h/g.
Modified by inspyral at 2:27 PM 9/28/2003
Old Sep 28, 2003 | 01:03 PM
earl's Avatar
Default Re: ? about headgaskets and copper spray. How much will it thicken the gasket? (Boostfed)
I have never calculated this but I can't imagine it affecting anything more than .001". The spray will just squeeze out or move to lower spots before it will support the cylinder head. 4 good coats of copper spray may be a little excessive.
Old Sep 28, 2003 | 01:14 PM
Boostfed's Avatar
New User
Default Re: ? about headgaskets and copper spray. How much will it thicken the gasket? (earl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">I have never calculated this but I can't imagine it affecting anything more than .001". The spray will just squeeze out or move to lower spots before it will support the cylinder head. 4 good coats of copper spray may be a little excessive.</TD></TR></TABLE>
What's the worst that could happen? I thought about it before and figured yeah since it squishes then it shouldn't add too much due to the malleability of the copper spray.
Old Sep 28, 2003 | 02:53 PM
earl's Avatar
Maybe if you stop to think about it, the answer would be zero.
Would not the pressure of combustion just blow right thru it? I think it just fills any low spots.
Old Sep 28, 2003 | 04:05 PM
Boostfed's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">Maybe if you stop to think about it, the answer would be zero.
Would not the pressure of combustion just blow right thru it? I think it just fills any low spots.</TD></TR></TABLE>
??????? What are you saying Earl? Are you against copper spray? Combustion blowing through the copper? Zero as in no additional thickness to the gasket?
Old Sep 28, 2003 | 06:10 PM
earl's Avatar
Im saying it works to fill all the minor indentations, machining marks, scratches, etc but I'm thinking it may not help hold compression at all. I am not 100% sure on this however.
Jdmb16sir2
Oct 26, 2007 12:23 PM
WOODman
Jun 6, 2005 04:08 PM
Powered By Garrett
Mar 7, 2005 06:50 PM
jdm_redneck
11
Mar 16, 2004 09:37 PM
civicnar
10
Mar 12, 2004 05:52 AM
