93 Integra LS Motor into a 93 Civic Coupe... How hard...
How hard is it to install the 1993 Integra LS Motor into a 93 Civic Coupe??? Im not positive on a couple of things but dont the 90-03 Integra's have Cable Tranny's where as the 92-95 Civic's have the Hydraulic? Will the axels fit or will I need to buy new axels... How about the mounts???
He is selling the motor for $800. Thats a good deal over here, but if it's going to take a lot of work should I just wait and get a B18B?
it is not hard, all B series will mount up the same. The only thing you will need would be a hydro b-series tranny. 94-01 integra have hydro trannys as well as del sol VTEC's and 6th gen SI's. use the axles from that integra use the same mounts. THey are the same chassis, you will need to think about converting to OBD-0 or making the engine OBD-1 though. good luck
Well Im not going to be doing the swap. Im taking it to my mechanic Jay Annunzio. And I was just wondering if it is a hard swap to do. If I will need to purchase any other products for the swap to go in smoother.
So what your saying is the mounts from the 90-93 Integra will work with the 92-95 civics?? All I need is a 94-01 B-Series tranny...
Also, do you think I'd be better off saving up enough to do a B16 Swap or maybe a H22??? Or just do the LS motor and slap a VTEC head on it...??? Which do u think I should do...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by compwc18 »</TD></TR><TR><TD CLASS="quote">Well Im not going to be doing the swap. Im taking it to my mechanic Jay Annunzio. And I was just wondering if it is a hard swap to do. If I will need to purchase any other products for the swap to go in smoother.
So what your saying is the mounts from the 90-93 Integra will work with the 92-95 civics?? All I need is a 94-01 B-Series tranny...</TD></TR></TABLE>
he means to keep the mounts from your civic
g2tegsownsgirl
May 1, 2006 08:36 AM
