b18a in 93 coupe help!
ok well i just picked up a 93 coupe and i want to swap in a 90 b18a motor and im not sure if its possible and if it is what do i need to swap it in i also got the 90 tranny i want to put in thank you for replys
Re: (sorrule)
http://hasport.com/products/mount_kits/egb1.htm well thats the mounts im getting but what ecu and somebody was telling me i could make my motor work with a obd1 ecu by swappin fuel injectors and distributor
Re: b18a in 93 coupe help! (whiteteg90)
ok well i did some researching and found to get it in i can run hasport mounts with the hydro to cable conversion,94+ integra injectors,b series throttle cable,94+ integra obd-1 distributor,a p75 ecu, but they say 94+ axles will my 90-93 be ok and they said something about o2 sensors but i wasnt too sure on that and is there anything else i need to do a direct bolt in thanks
Re: (sorrule)
aight thank you for being the only one to answer me lol no but really thanks for the help very much appreciated also do you know if i need any wiring harnesses
compwc18
09-28-2003 02:01 PM
