Mini Me- Timing issue. d16y8 on d16a6.
Old Sep 28, 2003 | 09:08 AM
xmd's Avatar
xmd
Default Mini Me- Timing issue. d16y8 on d16a6.
Ok, Now I've worked out all the electrical problems got the computer and injectors working and ive noticed that i cant get the y8 head in time its 1 tooth off always... I used the y8 belt with the a6 block.
I have a d16y8 head, d16a6 block and d16y8 timing belt.
I've noticed that the timinmg marks are 2 arrows that are not exactly str8 across..
Anyone done this swap that can lent some advice? Other than buying an adjustable cam gear.
-x m d
Old Sep 28, 2003 | 09:09 AM
Timmah!!'s Avatar
Default Re: Mini Me- Timing issue. d16y8 on d16a6. (xmd)
You might need an adjustable cam gear. Look that up and see what you can find.
Old Sep 28, 2003 | 09:30 AM
91civicEX's Avatar
Default Re: Mini Me- Timing issue. d16y8 on d16a6. (azroth)
with a z6 head the cam will be 1/2 a tooth off so you need an adjustable cam gear. does it sound like its firing up? check your firing order.
Old Sep 28, 2003 | 09:32 AM
xmd's Avatar
xmd
the car runs.. poorly. the firing order is correct. it just seems that the timing is off. in all the posts I've seen about the swap there isnt a mention of an adjustable cam gear so thats why i was wondering. It looks like the y8 timing mark is slighty skewed.. not str8 across so i was wondering if moving it back a tooth would help...
-x m d
Old Sep 28, 2003 | 09:59 AM
xmd's Avatar
xmd
Default Re: (xmd)
on a note, i did retard the timing.. one tooth.. clockwise..
And it runs. well enough. not to bad. but i can tell not in time. and i cant adjust the distro to muc to compensate. looks like its time for that aem cam gear.
-x m d
Old Sep 28, 2003 | 10:05 AM
EG8R's Avatar
Default Re: (xmd)
Skunk2 gear.
Old Sep 28, 2003 | 07:58 PM
whybother's Avatar
Yeah, no one really ever mentions it but you'll need an adjustable cam gear. I have Z6 head on A6 block and it was off about 2 degrees, or 1/2 tooth, with the stock gear. However it ran fine without the adjustable cam gear. A couple degrees shouldn't make a huge difference.
Old Feb 4, 2019 | 07:01 AM
Krauthammer's Avatar
Default Re: (xmd)
-x m d
Tuning will also help with ignition timing/ A/F ratios. mine was very rich until I tuned it
Shawn_71288
Jul 7, 2019 10:53 PM
Dueceification
10
Feb 4, 2019 07:03 AM
flatblack-h22
12
Dec 28, 2006 05:23 PM
