my b16 emits black smoke?
Old Sep 28, 2003 | 08:35 AM
egracer44's Avatar
Default my b16 emits black smoke?
Guys I need help I'm worried because my engine which has only 2000 km in it started blowing
black smoke. I seldom use my car only for short distances and a couple of races(drag). I changed the
plugs this morning and it lessened a bit. What do you guys think causes it? Thanks in advance.
Old Sep 28, 2003 | 08:38 AM
advanracing62's Avatar
Default Re: my b16 emits black smoke? (egracer44)
diesel fuel?!? do a compression check and leak down test.. that should help pinpoint if it's rings, etc. what colour were the plugs? any fuel adjustments lately?
Modified by advanracing62 at 11:41 AM 9/28/2003
Old Sep 28, 2003 | 09:30 AM
projectTeG's Avatar
runnin rich
Old Sep 28, 2003 | 09:48 AM
allmtr's Avatar
Default Re: (projectTeG)
your b16's burning oil
Old Sep 28, 2003 | 04:48 PM
projectTeG's Avatar
i thouht that burning oil = ble or sumtimes white smoke
and
black smoke= runing rich?
Old Sep 28, 2003 | 05:59 PM
allmtr's Avatar
black smoke is burnig oil.
white smoke is burning coolant. (there are some acceptions like condensation and such...)
running rich has nothing to do with it. rich is just more gas than air.
Old Sep 28, 2003 | 06:09 PM
projectTeG's Avatar
then whats blue smoke?
Old Sep 28, 2003 | 06:14 PM
allmtr's Avatar
oil and coolant. probably just oil though
Old Sep 28, 2003 | 06:34 PM
philafelman's Avatar
Default Re: (allmtr)
burning oil i blue or black smoke, coolant is white... and running rich can cause black smoke out the tailpipe.
Old Sep 30, 2003 | 04:13 PM
projectTeG's Avatar
see? i thought i was on the right track...somewhat
Old Sep 30, 2003 | 04:49 PM
allmtr's Avatar
Default Re: (philafelman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philafelman &raquo;</TD></TR><TR><TD CLASS="quote">burning oil i blue or black smoke, coolant is white... and running rich can cause black smoke out the tailpipe.</TD></TR></TABLE>
i didnt think running rich effected smoke color... hmmm. anyone else know anything bout this?
Old Sep 30, 2003 | 05:41 PM
Spids5's Avatar
Don't judge or question
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmtr &raquo;</TD></TR><TR><TD CLASS="quote">black smoke is burnig oil.
running rich has nothing to do with it. rich is just more gas than air.</TD></TR></TABLE>
Black smoke is when you are running rich and blue smoke is when your burning oil. When your burning oil usually the oill will leave blue spots on your bumper.
Old Sep 30, 2003 | 06:06 PM
allmtr's Avatar
Default Re: (spids5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spids5 &raquo;</TD></TR><TR><TD CLASS="quote">
Black smoke is when you are running rich and blue smoke is when your burning oil. When your burning oil usually the oill will leave blue spots on your bumper.</TD></TR></TABLE>
gotcha. i just went by dark smoke to light smoke.
Old Sep 30, 2003 | 06:42 PM
myke's Avatar
From: South LA...107th and fig to be exact...for the foo
sell it!
Old Sep 30, 2003 | 07:01 PM
99-DC2's Avatar
more likely it runs rich... i get black smoke especially when vtec engages... then again with these engines it must run on the rich side to get the most out of them...
Old Sep 30, 2003 | 07:03 PM
projectTeG's Avatar
haha...i was right
Old Sep 30, 2003 | 10:26 PM
SEA Hag's Avatar
Default Re: my b16 emits black smoke? (93eg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93eg6 &raquo;</TD></TR><TR><TD CLASS="quote">more likely it runs rich... i get black smoke especially when vtec engages... then again with these engines it must run on the rich side to get the most out of them...</TD></TR></TABLE>
VTEC wont cause black smoke if your engine is in good condition. And how does running rich make you get the most out of your engine?
Old Oct 1, 2003 | 08:13 AM
goodbyegti's Avatar
black smoke is running rich, even if you don't look at what colour it is you can smell oil burning... sounds like your fuel map is slightly off, its better to run rich than run lean anyway...
Old Oct 1, 2003 | 12:23 PM
hatehaterz's Avatar
Default Re: (goodbyegti)
yo ,,,, is it difficult to change the valve seals? i have the same proble.. my car runs pretty well but i mishifted a couple of time and ever since it throw smoke at wot... sorry didnt mean to get the attention from the actual creator of the post but i'd figured i should ask...
Old Oct 1, 2003 | 01:19 PM
Rhetoric's Avatar
Default Re: (hatehaterz)
valve seals can be changed with the head still on the block, I think it is more difficult that way since you have to keep the valves up after removing the keepers.
Do a compression/leak down to better pin point. Blue smoke is oil, you'd be able to smell it as well.
Old Oct 1, 2003 | 07:03 PM
99-DC2's Avatar
Default Re: my b16 emits black smoke? (SEA Hag)
AF ratio of between 12.5-13... that's how my engine works anyway...
Old Oct 3, 2003 | 05:02 AM
htownteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goodbyegti &raquo;</TD></TR><TR><TD CLASS="quote">black smoke is running rich, even if you don't look at what colour it is you can smell oil burning... sounds like your fuel map is slightly off, its better to run rich than run lean anyway...</TD></TR></TABLE>
ditto..except that running rich burns gas like a ****
Old Oct 3, 2003 | 06:05 AM
goodbyegti's Avatar
Default Re: (htownteg)
personally i'd rather use some extra fuel than have preignition...although neithers great
Old Oct 3, 2003 | 06:25 AM
ALLMTRWHORE's Avatar
yeah your running rich, it's ok just think of it as a smoke screen when you punch it!
GSR_hatch936
21
Apr 28, 2007 11:10 PM
SlammedBlackGSR
Jul 6, 2006 10:55 AM
Teamdiesel
12
Apr 25, 2006 06:21 AM
KustomCrx
Aug 26, 2004 11:16 PM
LB CRX
Sep 1, 2002 12:07 PM
