How to??? (Install keyless entry on 5th gen civic EX)
Old Sep 28, 2003 | 04:40 AM
ninety9ex's Avatar
Default How to??? (Install keyless entry on 5th gen civic EX)
I bought the kit, and it didnt really come with much in terms of directions... Can anyone help?
BTW: I did search, I have been searching the past 30-45 minutes... Please help
Thanks in advance!
Old Sep 28, 2003 | 01:35 PM
Abe Froman's Avatar
Default Re: How to??? (ninety3EX)
Is this a stock keyless module?
Old Sep 28, 2003 | 03:17 PM
ninety9ex's Avatar
Default Re: How to??? (Abe Froman)
no, its not a stock/factory kit, I didnt know they have one, It's an aftermarket module, I know where to hook up everything but the lock-unlock wires
Old Sep 28, 2003 | 05:07 PM
Abe Froman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ninety3EX &raquo;</TD></TR><TR><TD CLASS="quote">no, its not a stock/factory kit, I didnt know they have one, It's an aftermarket module, I know where to hook up everything but the lock-unlock wires</TD></TR></TABLE>
Yes, they made them, but you'd likely be out of luck finding one from a '95.
To answer your question, look up above the driver kick panel, kinda behind the fuse box. There's a plug with 2 wires, it should be taped to a larger harness with blue tape (unless the wiring uder there's already jacked up). They might be green wires with a white or orange stripe, but I'm not sure - it's been a while since I've done one. Negative trigger - that simple.
The ONLY thing to look out for is that on a couple of 92-93's, that connector doesn't actually go all the way to the relays - it stops in the door grommet connector, in which case you'll need to run wires into the door. However, I won't go into those details unless you find that's the case.
Old Sep 28, 2003 | 05:20 PM
ninety9ex's Avatar
yeah, it's a 93 and the control box and wires are all inside the door... sounds like i have some work now, Thanks for the info and i will be waiting on the details... BUT, JUST went and looked and the plug is exactly where you said ti would be... thanks a ton!
MurphyEF
Aug 12, 2010 03:38 PM
Bok Choi
Jul 8, 2006 03:10 PM
CooBlueDAB
Audio / Security / Video
Nov 7, 2004 06:56 AM
zalock
Mar 27, 2004 06:11 AM
ninety9ex
Oct 5, 2003 06:44 AM
