What is the Piece that the brake caliper is bolted onto called?
i'm curious and i need one off an integra or ciic ex, whatever will fit the integra calipers. it connects the upper and lower control arms together. needs a ball joint puller to remove....
i came across free itnegra calipers all i need are disks, i just wanted to upgrade my diks up front to integra spec. please help if anyone knows what this peice is called.
sorry for my ignorance, but which part is the hub and which is the knuckle? and is it common to find integra knuckles on the classifieds or is it something that is most commonly found in a junk yard
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phantom_sol »</TD></TR><TR><TD CLASS="quote">sorry for my ignorance, but which part is the hub and which is the knuckle? and is it common to find integra knuckles on the classifieds or is it something that is most commonly found in a junk yard</TD></TR></TABLE>
The knuckle/spindle is the part you're talking about. The hub is in the spindle that you bolt your wheels to, etc. You can get them at a junkyard, but they're all over the classifieds.
2slowIntegraLS
Aug 5, 2016 02:16 PM
instrument
Nov 16, 2007 06:17 PM
LSEGHATCH
Sep 26, 2005 10:15 PM
