can you turbo a SH?
You can but if you boost too much...your ATTS system will get disabled if you spin the wheels too much. I would imagine it would eventually mess up your ATTS system.
Someone else please confirm this.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by logic »</TD></TR><TR><TD CLASS="quote">*cough* alreadydidfagthatswhyiposted *cough*</TD></TR></TABLE>
lol
lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by logic »</TD></TR><TR><TD CLASS="quote">the title is self explanitory, thanks guys
Fukin noob, go back to CivicSi.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integraL »</TD></TR><TR><TD CLASS="quote">you guys have nothing better to do, then flame huh...
*choke* youflamersshouldstfu *choke*</TD></TR></TABLE>
I agree. If you don't like the topic...don't respond.
not flaming or anything but PetroGuyX, why would it be not recommended to boost an SH???
its perfectly fine
theres a way to remove the ATTS and slap on a base tranny but theres more to it than that....
most people have the misconception that the SH and the ATTS is bad for boosting...why???? i dont see why not? its just a base with a worthless 80lb. box added to it thats all
its perfectly fine
Logic, I just ordered a rev hard for my 98 Sh.
Once it arrives and i install, Believe me I will keep you/the prelude forum posted on it's progress. Also It's regulated to 7psi and the turbo is a t3/t4 60trim 63A/R.....so it shouldn't mess with the atts unless you up the boost and...well I think you mite blow the motor before you have a chance to over power the atts.....
ok ok I guess that was harsh. I suggest you boost a base model rather than the SH beceause if you go higher than 270 hp then the ATTS turns off and is just useless dead weight. Go for a base and slap in a LSD.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenPoweredLude »</TD></TR><TR><TD CLASS="quote">.........
its perfectly fine
Actually, you are incorrect. The Type SH block is different than the Base block. You can't just slap on a Base tranny to a Type SH block.
its perfectly fine
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD »</TD></TR><TR><TD CLASS="quote">
Actually, you are incorrect. The Type SH block is different than the Base block. You can't just slap on a Base tranny to a Type SH block.</TD></TR></TABLE>
explain this to me...because the last time i checked, they were both h22's. So, they're trannies should be interchangable. And actually, the F22 tranny should bolt onto an H22 motor as well. That would be decent for a turbo'd 'Lude...longer gear ratios. Anyways...isn't there a way to disconnect the ATTS ? Someone told me it's part of the ECU ? I was like WTF !?! I don't think so...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urbanracer98 »</TD></TR><TR><TD CLASS="quote">
explain this to me...because the last time i checked, they were both h22's. So, they're trannies should be interchangable. And actually, the F22 tranny should bolt onto an H22 motor as well. </TD></TR></TABLE>
http://www.hondaautomotiveparts.com is your friend.
Also, yes, the F22 will fit ALL H22 blocks...EXCEPT for the Type SH.
here's a writeup on how to swap ATTS tranny with a base
http://ian.clendaniel.net/gallery/noatts
When I inquired about a jdm type-s(atts) tranny, I was quoted double the price of installing a base tranny, or s-spec, so it can be done but there is some modification involved that im unaware of..........
Actually they are the same bolt pattern, look at the post below you, there is a link to a guy's site that has an H23A tranny on his SH block, also it shows the difference between the SH tranny and an H23A tranny. The SH tranny casing is a little different then the base tranny, a little smaller. Much like the differences between the Base USDM tranny and the JDM lsd tranny, The JDM lsd tranny casing is a little larger to accomodate the LSD unit. That is also why you cannot put the JDM lsd in the USDM base tranny, it won't fit, the casing is too small.
