seals
well if you dont know what you are doing yeah it is hard ...
you got cam seal crank sealbalencer seal ( not a easy jobyou must pull the timing belt )
rear main seal (not easy you gotta pull the tranny )
i'm talking about the crank and cam oil seals. Assuming I got everything ie timing belt out already, will it be tricky to change them?
matix, u got to be bsing. That's pretty quick. My dealer said it would take 10 hours.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by david90 »</TD></TR><TR><TD CLASS="quote">
matix, u got to be bsing. That's pretty quick. My dealer said it would take 10 hours.</TD></TR></TABLE>
When you do them everyday they can be done in less than an hour.
Im not bsing your dealer is. The first time i did it it took 4 hours. And that was when i noticed the leak but didnt have the seal. So I got the seal and did it again a week later. After you do it once you dont run into the problems you do the first time and its a cakewalk.
I didnt buy the balancer shaft seal. And when i opened it up that was were the leak was and they had to order the seal. So i had to do it again when i received the seal. and no seals are easy to put in just use a giant socket
dealers always bs. they told me 4-5 hours to replace some shocks, it ended up taking me about 2 hours with some major complications (one of the threads on the struts was fuxed and i had to repair it).
changing the seals and timing belt shouldnt be too hard if you know what you're doing, pick up a helms manual, maybe even a haynes if you dont wanna spend that much, and you'll have a pretty good reference while you do it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fluxion »</TD></TR><TR><TD CLASS="quote">
changing the seals and timing belt shouldnt be too hard if you know what you're doing, pick up a helms manual, maybe even a haynes if you dont wanna spend that much, and you'll have a pretty good reference while you do it.</TD></TR></TABLE>
4-5 hours maybe because of waiting time and double checking and other customers, dealerships want to do a good job.....but year, takes about 2 hours to replace shocks and springs/coilovers...
i dont mean 5 hours like..."yah, well have it back to you in 5 hours", 5 hours as in:
them: it'll cost about $400 to replace them
me: wtf?
them: yah, 5 hour job, $80 per hour.
me: wtf?
TOO MUCH TORQUE
Feb 13, 2015 06:13 PM
mclasser
Dec 25, 2013 11:41 PM
my93accord
Jul 1, 2010 06:06 PM
no1knows908
Jul 14, 2007 07:06 PM
