Question about a Type R tranny?
Old Sep 27, 2003 | 06:39 PM
APEX i GSR's Avatar
Default Question about a Type R tranny?
I know this is a Type Rsection but i need a little bit of direction of which way to go.
I have a 96 GSR that i installed a brand new Type R transmission with a Toda flywheel & an ACT 6 puck clutch. I had this setup for 2 years. After driving with setup for so long the inevitable happened about 6 months ago. The car just stopped one day. My guess is the differential broke or the differential pin broke.
I haven't taken it apart yet just because of time. I was also lucky to have a wife with a 91 Civic Std with a B16 thhat she would let me drive.
My question is which should I do?
1: Buy a new tranny from Acura
2: Rebuild current trans with a used JDM ITR diff that i can get used with about
20K on it
My other question is: Is there a difference between the JDM ITR LSD & the USDM one?
To those that have had this happen how extensive was the damage to the tranny & what did you do to remedy this situation?
Old Sep 27, 2003 | 06:41 PM
GokuSSJ4's Avatar
Default Re: Question about a Type R tranny? (APEX i GSR)
some times is not worth to repair the tranny ,
Old Sep 27, 2003 | 06:58 PM
Bbasso's Avatar
Take it apart and see what failed before you decide on anything, could be easy and cheap to fix.
Old Sep 27, 2003 | 08:25 PM
Black R's Avatar
25 Year Member
.....I remember you saying how much you hated that clutch.
Wanna get rid of it, or the tany or both?
Old Sep 28, 2003 | 08:01 AM
APEX i GSR's Avatar
Default Re: Question about a Type R tranny? (Black R)
The clutch is still good
what do you have as a replacement?
IM me with details
I need to get this car running again
Old Sep 28, 2003 | 08:31 AM
sneakychaos's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by APEX i GSR &raquo;</TD></TR><TR><TD CLASS="quote">
20K on it
My other question is: Is there a difference between the JDM ITR LSD & the USDM one?</TD></TR></TABLE>
No difference between the diffs. What year tranny do you have, only thing that might be different are the carrier bearings.
I'd take the tranny apart before I bought a new one... find out whats broke as recommended above and then decide.
Old Sep 28, 2003 | 03:50 PM
APEX i GSR's Avatar
Default Re: Question about a Type R tranny? (sneakychaos)
the tranny i have was purchased new in 2001
i guess it is considered a 2001
Old Sep 28, 2003 | 05:46 PM
00-ITR-373's Avatar
IF you can find a new tranny from Acura, you're have more skills than I do. I tried for over three months to find a new tranny, and supposedly the wait is at least 6 months. Good luck. I'd try my best to repair that tranny with new parts, not a new tranny.
Old Sep 28, 2003 | 08:39 PM
vtec.dc2's Avatar
Default Re: Question about a Type R tranny? (Bbasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">Take it apart and see what failed before you decide on anything, could be easy and cheap to fix.</TD></TR></TABLE>
that sounds like better option.. make sure its not clutch or anything
Old Sep 29, 2003 | 03:52 AM
APEX i GSR's Avatar
Default Re: Question about a Type R tranny? (00-ITR-373)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00-ITR-373 &raquo;</TD></TR><TR><TD CLASS="quote">IF you can find a new tranny from Acura, you're have more skills than I do. I tried for over three months to find a new tranny, and supposedly the wait is at least 6 months. Good luck. I'd try my best to repair that tranny with new parts, not a new tranny.</TD></TR></TABLE>
the trannys have been released off backorder just contact Len
i'm beginning to think about rebuilding but is a JDM ITR LSD the same as a USDM or is a CTR LSD the same as a US one
lsvSwagg
Oct 4, 2012 06:28 PM
bcrosby51
Jul 26, 2007 12:11 PM
JuicyJDM
Jul 13, 2007 02:02 PM
julian_gq
Jun 1, 2005 09:01 PM
99integraboy
Mar 13, 2003 07:19 AM
