Tranny
Old Sep 27, 2003 | 06:08 PM
Apollo's Avatar
Default Tranny
K well its stuck in second gear i can also get into all gears but second... id imagine that i blew second gear out. and if so how hard is it to replace a gear and two can i pull the tranny out from underneat or is the suspension gonna be a bitch.
btw this is on a 91 civic si daily driver just happened today when i reved up to bout 6500
thx for the help
Old Sep 27, 2003 | 06:26 PM
Apollo's Avatar
Default Re: Tranny (Apollo)
bump
Old Sep 27, 2003 | 07:22 PM
Apollo's Avatar
bump? anythoughts at all?
Old Sep 27, 2003 | 07:23 PM
Kwicko's Avatar
Sorry I can't offer more help, but I'll do what I can.
First off, you'll have to remove the tranny to figure out what's going on, so we'll start there. Yes, you definitely *can* take it out the bottom. It's not exactly *easy*, but there really is no quick and easy way to take it out. The biggest part of the work, to me, is just getting all the other stuff out of the way so you can get at the transmission mounting bolts.
Yes, you'll want to pull some of the suspension, but not all of it. You'll need to remove the axles, which will require you to remove the strut/spring unit and the strut fork, and you'll need to pop the ball-joints loose at the bottom of the hub/knuckle assembly.
One note: BEFORE draining the transmission or removing the axles, find and loosen the transmission filler bolt. Nothing's more of a pain in the butt than having an empty transmission and NOT being able to get that bolt loose to re-fill it!
As for replacing a gear, I can't say how hard it is, but it IS a do-able thing. But where to find the gears? My *guess* is that it's more likely a shift fork inside the transmission; gears are hardened steel, shift forks are aluminum, and I've seen a few broken ones.
If you're going to crack the transmission open, you NEED a good service manual. Follow directions, and pay close attention to how everything goes together. It's a precision machine, and getting things "close" won't work, unfortunately.
Your best bet may well be to replace it with a used transmission. As it's a '91 Si, you want a '90 or '91 Si transmission. You *can* use an '88 or an '89, but you'll need the right clutch and flywheel for them, since they are different-sized friction surfaces than the '90-'91.
Also, if you just need to get your car moving again, you can use a DX or HF transmission from similar years ('90 or '91). They'll work on the car, but your gear ratios and acceleration will suffer. Also, you might have to get different axles to use those. But the transmissions are usually cheaper (and there's a reason for that - they're not as quick!).
Have we helped yet? The good news is, you've got options. The bad news is, they'll likely all cost you money and work. Sometimes, all you can do is smile and think of it as a "learning experience".
Mike
Old Sep 27, 2003 | 07:32 PM
Apollo's Avatar
Thanks for the reply kwicko... i just was hoping to get it done and thanks for the info. I wonder how hard it is to fix the fork myself... cuz either way if i take it to the hsop to get fixed itll be a lil bit of cash but id rather have them do it than have me **** up on something i need... But thx again.
Old Sep 27, 2003 | 10:43 PM
USDM 4G VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Apollo &raquo;</TD></TR><TR><TD CLASS="quote">K well its stuck in second gear i can also get into all gears but second... id imagine that i blew second gear out. and if so how hard is it to replace a gear and two can i pull the tranny out from underneat or is the suspension gonna be a bitch.
thx for the help </TD></TR></TABLE>
i have been tru that about 2 times and my buddy 1once....
i fixed them all the time...
u broke the 1st and 2nd select fork..... replace it.... need to open the whole tranny....
i think i did a post about it a while back.. search for my name...
2wheelhunter
Dec 8, 2006 10:15 AM
ThinkRevolution
Dec 1, 2006 06:04 AM
shutta
Jun 19, 2006 03:18 PM
kranked91dx
21
Jan 27, 2003 06:44 AM
