HELP with VSS
HELP with VSS
Ok, so I was in the middle of replacing my VSS. I see that its basically a three part system.
Female plug - - Male plug w/ base - - - core with gear
I undid the 3 10mm bolts holding the two plugs in, now i'm left with the spring for the core showing, and no way to get it out. I tried prying a bit, but didn't want to break anything. How do I get the little yellow gear out of the tranny? (I only know its there because I see it on my replacement) I can already tell the male version of my VSS was busted, as its missing the entire ring.
Re: (Jimmy)
thats what I figured, but all the wiggling and prying i can seem to do wont get it off. I was worried that I would break the teeth off the yellow gear.
Global Moderator
Re: (ThinkRevolution)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThinkRevolution »</TD></TR><TR><TD CLASS="quote">thats what I figured, but all the wiggling and prying i can seem to do wont get it off. I was worried that I would break the teeth off the yellow gear.</TD></TR></TABLE>
You'll be fine, did u get it out?
Re: (Jimmy)
No, was waiting for the go ahead that I wouldn't snap the teeth. I have the top half disassembled at the moment (with the 2 10mm bolts) and I have the third bolt out, I just didn't want to really get at it and break something.
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThinkRevolution »</TD></TR><TR><TD CLASS="quote">No, was waiting for the go ahead that I wouldn't snap the teeth. I have the top half disassembled at the moment (with the 2 10mm bolts) and I have the third bolt out, I just didn't want to really get at it and break something.</TD></TR></TABLE>
it's not going to break.. its fine
