bore out tb?
Old Sep 27, 2003 | 04:08 PM
b16_madman's Avatar
Default bore out tb?
Ok, I could get my tb a taper cut for it for pretty cheap here at a machine shop.
It would keep the same throttle plate.
What would this do for my b?
A little better throttle is always nice....I just want to know is it a waste of $$
or not?
Is it better just to buy another tb with a bigger bore?
Old Sep 28, 2003 | 02:15 AM
STEALTHMODECOUPE's Avatar
Default Re: bore out tb? (B16_madman)
youll gain a couple top end HP by doing it but its best to have the intake manifold port matched with the TB and youll see better results..
adaM
Old Sep 28, 2003 | 04:00 AM
snowseeker's Avatar
Kepp the same throttle plate? To go any bigger you need a new plate.
Old Sep 28, 2003 | 11:02 AM
b16_madman's Avatar
Default Re: bore out tb? (snowseeker)
I was thinking just a tapered cut. Kindof a funnel effect. Some guy said it helps...
Old Sep 29, 2003 | 11:57 AM
snowseeker's Avatar
ohhh like a bell cut? It helps if you run a open TB. But if you have any kind of intake on it, that defeats the funnel effect.
kulo
Jan 27, 2009 11:08 AM
polishedturd
Jan 11, 2008 10:11 AM
ACrite3404
Feb 1, 2007 09:49 AM
nissanjon
Apr 26, 2005 04:59 AM
pearlteg
Dec 18, 2004 05:56 PM
