broke a wheel stud
Old Sep 27, 2003 | 03:05 PM
tonezilla's Avatar
Default broke a wheel stud
i just broke off two of my wheel studs because of some alignment place i went to crossthreaded my lugs . mann . i just wanted to know if i could drive it to a shop 15 mins away to replace my wheel studs since i only have two left now on the right front of a 94 accord lx . or is it too dangerous ? please help . thanks .
Old Sep 27, 2003 | 03:47 PM
iam7head's Avatar
Default Re: broke a wheel stud (redxalien)
torque it good and drive ultra slow..
Old Sep 27, 2003 | 03:56 PM
iam7head's Avatar
Default Re: broke a wheel stud (iam7head)
those buttninja works at the shop should pay for it..i see too much dumbasses bust those stud with an air gun.
they will never hand tighted and torque down like it should.
Old Sep 27, 2003 | 03:59 PM
soodark's Avatar
shitty man. I broke one of mine off, when I was rotating my wheels front to back, (with no power tools) I drove it to the dealership on three studs, but 2 is kinda pushing it. Be careful, and drive slow.
Old Sep 27, 2003 | 04:10 PM
iam7head's Avatar
Default Re: (soodark)
make sure those grease monkey use torque wrench, i bring mine to the shop all the time, just in case those sucka dont have one.
Old Sep 27, 2003 | 04:19 PM
tonezilla's Avatar
damm . you guys make me dont want to drive my car anymore . ahaha . making me scared . i tried researching around this board and it said i could do it myself . i tried but i had a hard time when i had to take off the bolts on the caliper mounts . there so goddam tight . because i was planning to punch the studs out . o well i guess ill just take your guys advice and drive real slow to the shop tomorrow . how slow should i go i just want to make sure i dont get stranded on the street ?!
Old Sep 27, 2003 | 04:24 PM
XMarkGuerillaX's Avatar
i broke a studd ounce you gotta press out the hub have a shop do it. trust me.
Old Sep 27, 2003 | 04:39 PM
iam7head's Avatar
Default Re: broke a wheel stud (XMarkGuerillaX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XMarkGuerillaX &raquo;</TD></TR><TR><TD CLASS="quote">i broke a studd ounce you gotta press out the hub have a shop do it. trust me.</TD></TR></TABLE>
on accord they are pressed, i think..
you can put anti-seize(SP) on the stud and it will not fall off, if the wheel fasteners(aka lug nuts) is properly tighten(torqued down)
it make it easier to remove the rims next time, you never know when you'll have a flat tire and your sh_t wont budge in middle of the night in a bad neighbor
Old Sep 27, 2003 | 04:55 PM
tonezilla's Avatar
mann . honda wants to charge me $120+tax to replace one of my studs . is this how much everyone else charges too . how much should i expect it to be to get it replaced ?
Old Sep 28, 2003 | 06:29 PM
AccVic's Avatar
Default Re: (redxalien)
that's way too much it's really not that hard if you can get an air gun I changed my studs myself with an air gun the only hard part was getting the caliper back on or what you could do is go by discount tire they might fix it
Old Sep 28, 2003 | 06:37 PM
brads94accord's Avatar
hahaha dang, 120$!!!!??? thats outrageous. i had to replace four of mine on my driver side front because the guy at some hole in the wall shop that put my tires on stripped my lugs, and kauffman tire charged me $33 for everything.
Old Dec 1, 2003 | 08:23 PM
XDEep's Avatar
Default Re: (brads94accord)
ya just drive slow. youll know lugs are getting loose when your wheel starts shaking and you might hear clammering.
when the wheel be a shakin, pull over immediately!
Old Dec 2, 2003 | 02:44 AM
sloaccord's Avatar
New User
Default Re: (XDEep)
lol
at least yours broke off
mine seized on. i tried busting it off with a 3/4 drive impact gun and that wouldnt even get it off.
i finally had to drill through the nut and then drill into the bolt. that sucked.
dingusjt
Honda Civic (2001 - 2005)
10
Apr 23, 2009 06:18 PM
vtec_lude
Jun 19, 2004 02:21 PM
migs
Dec 30, 2002 08:57 AM
DSPDA3
23
Nov 23, 2002 06:49 PM
integra0260
Oct 6, 2002 05:40 PM
