Oil filter block adaptor
Old Sep 27, 2003 | 02:47 PM
Que_Lude's Avatar
Default Greddy Oil filter block adaptor
Anyone install one of these on their ludes? (For an Oil pressure gauge) Was thinking about it but the oil filter area under the H22a is pretty tight. Just wondering if I can get the filter on after installing this thing...
Old Sep 27, 2003 | 03:04 PM
LudeyKrus's Avatar
that's that thing supposed to do?
Old Sep 27, 2003 | 03:37 PM
RHD_BB4T's Avatar
Default Re: (LudeyKrus)
It screws on between your block and oil filter to give you access to oil pressure, oil temp, ect. There are several threaded fittings on it to either put sensors or even run/tap for an oil feed.
Greddy(oops, that IS the Greddy one) sells one simillar and so does Golden Eagle Mfg., both designed for vtec head conversions... They work pretty good, and at the size of most B-Series oil-coolers, you shouldn't have a hard time using it.
That's about all I know though...HTH
Dan P
Old Sep 28, 2003 | 02:17 PM
Que_Lude's Avatar
Default Re: Greddy Oil filter block adaptor (Que_Lude)
Yup, it's for Oil Pressure and/or Oil Temp. So no one has one on their 4th gen lude??? I want to make sure that I will be able to get my oil filter on after installing this thing. As the 4th gen Vtec owners know, there isn't much space around the oil filter...
Maiyen
13
Dec 26, 2017 04:20 AM
vCarNage
Jan 31, 2014 08:46 PM
DavidR
Feb 13, 2006 04:03 PM
The Phil
Jul 17, 2005 07:46 PM
DR. ON POINT
Sep 22, 2002 06:08 PM
