Which is safer? Wet or dry nitrous?
Old Sep 27, 2003 | 12:28 PM
BseriesHatch's Avatar
Default Which is safer? Wet or dry nitrous?
I want to get a nitrous kit to throw on my B20Vtec. I've seen many people selling thier Zex kits for pretty good prices. Just wanted to wee which one is safer because i want to run a 75 shot and not have to worry about blowing my motor. I have had a wet kit on my old hatch with a ZC and it ran strong with a 75 shot. Just don't know though if a dry kit will be as safe as a wet kit. Any suggestions help or if any has a kit they are selling for around $300 just let me know. Thanks.
Old Sep 27, 2003 | 01:34 PM
escocrx's Avatar
Default Re: Which is safer? Wet or dry nitrous? (BseriesHatch)
id git wet. since it controls fuel also. but thats jus me.
Old Sep 27, 2003 | 01:59 PM
TwztdSi's Avatar
I have a couple of questions. How did they zc handle the 75 shot? Was it a stock zc? I'm running a 50 shot now and I would like to bump it up to a 75 but i'm a little afraid too, can't afford to blow my motor right now.
Old Sep 27, 2003 | 02:30 PM
EF Two's Avatar
Default Re: (TwztdSi)
Just keep it 50 and you'll be aight. My friend had a ZC until he sprayed a 75 shot. Nows there a big hole in the block where I can stick my hand through
Old Sep 29, 2003 | 06:40 AM
My ZC ran strong with the 75 shot for like three months till it got stolen . But like a week before it got stolen i compression tested it and it was still like 160 across the board. It depends on the condition of the motor you have. Mainly do it at your own risk but mine ran perfect.
Old Sep 30, 2003 | 11:59 AM
Default Re: (BseriesHatch)
Bump
Old Sep 30, 2003 | 04:16 PM
blah13's Avatar
75 wet on the ZC is easily done. Wet is generally more safe as it keeps your a/f ratio correct without the need for a fpr or s/v-afc. The only drawback is if your valve timing gets fucked and you get backfire into your intake mani.....backfire + gas in mani = no fun. As for your b20 get the wet if you can.
Old Oct 2, 2003 | 09:04 AM
OneFastGsr's Avatar
Default Re: (blah13)
I heard that a wet kit is not good for a gsr is that true?
Old Oct 2, 2003 | 09:32 AM
USDMMARK's Avatar
Default Re: (OneFastGsr)
would like mor info on this wet or dry?
Old Apr 27, 2004 | 06:01 PM
londa hover's Avatar
Default Re: (ORIGIN[AL])
how does wet nitrous work? i know dry is where it hooks up to your intake and direct port is when its hooked up to your fuel injectors but where does wet nitrous hook up?
Old Apr 27, 2004 | 06:07 PM
krazie1's Avatar
BANNED
Default Re: (londa hover)
wet is hella better since it shots in with fuel also that is how it works
Old Apr 27, 2004 | 06:19 PM
outkast's Avatar
Default Re: (krazie1)
very interested, if anyone can post any additional info. looking for the best option for a b18a1.
bacnoonoi
Dec 5, 2008 05:06 PM
djmesican
15
Sep 29, 2007 09:15 PM
95240sxer
Dec 23, 2004 01:14 PM
BseriesHatch
Dec 12, 2002 12:21 PM
91HATCH
17
Feb 13, 2002 03:17 AM
