toda stroker kit
Old Sep 27, 2003 | 09:08 AM
jaydmcrx's Avatar
Default toda stroker kit
Anyone know of horsepower gains with the toda stroker kit in a first gen b16a1. I'm thinking of doing this, just wondering if its worth it?
Old Sep 27, 2003 | 09:35 AM
skribblah's Avatar
Default Re: toda stroker kit (jaydmcrx)
just get a B17 crank and B17 rods... i have the crank for sale...
Old Sep 27, 2003 | 10:11 AM
Mr Hammond's Avatar
a/k/a Jomo
It's basically a GSR/ITR 87.2mm crank and 11:1 pistons with custom rods 1.54:1 R/S ratio. With stage 1 cams you coudl probably get around 180+.
Old Sep 27, 2003 | 11:19 AM
B18CEG6's Avatar
Don't spend the money on the toda stroker.
Since your willing to disassemble the engine, I would sleeve it for 85mm pistons, run around 11.5 to 12:1 for pumpgas, if your B16 is JDM I would recommend just getting the rods shot-penned and using some ARP rodbolts. The big bore will unshroud the valves and give you more displacement, you will have 1748cc, with a killer rod/ratio. Make sure you have a cam to go with this, no less than 250 degree @ 50
My friend made 203hp to the wheels with a big bore B16.
Old Sep 27, 2003 | 05:50 PM
jaydmcrx's Avatar
So just punch it out, get some beefy or shot peened rods, and get a mean head to go along with it is what your saying? And obviously this will be cheaper than the toda stroker kit wich the cheapest i have found is 2600 by the way. Can you show me a sight where this has been done?? Kind of like a parts list set up or anything like that? Anything like that would be much appreciated.
vtec8200
14
Oct 24, 2011 06:01 PM
NA_VTEC
Jul 20, 2005 05:19 AM
civdx94
Dec 11, 2003 08:15 PM
erck19
Oct 3, 2003 10:19 PM
Darkteg
Mar 19, 2003 09:43 AM
