Shifter counter weight was cut off? What to replace?
Old Sep 27, 2003 | 08:23 AM
AgentJam's Avatar
Default Shifter counter weight was cut off? What to replace?
Shop said the guy before me cut the counter weight under my shifter, it's making my car give off a grinding/vibrating sound when i'm in 1st gear at like 10mph. Does anyone know where this counter weight is and what it is connected to? Do i need to replace a shift linkage? Maybe i can cut one off a junk yard and weld it back on.
Thanks,
Vince
Old Sep 27, 2003 | 09:29 AM
MrTodd's Avatar
Default Re: Shifter counter weight was cut off? What to replace? (AgentJam)
The counter weight is part of the shift linkage... I used a hack-saw to cut mine off because it hit my exhaust piping when I had my short shifter installed. I have since replaced my SS with the stock shifter, but I still don't have the counter wieght there... Mine makes wierd noises at times as well.
You can replace the counter weight by replacing the entire radius rod(i think, or maybe it's the torque rod? heh). It's a really simple procedure. You need to look at it to know what I'm talking about - the counter weight is actually an extension of the radius rod that extends past the bottom of the shift lever. Once you see where it is, then head to the nearest junkyard and pull off the necessary linkage component.
Old Sep 27, 2003 | 12:11 PM
carsaregood's Avatar
Default Re: Shifter counter weight was cut off? What to replace? (MrTodd)
i did the same thing.. cut that weight off because of a short shifter, but i don't have any sounds or weird vibrations.. maybe i just got lucky. but yeah, it looks like a black, heavy solid cylinder on the end of the torque rod.. closest to the rear of the car.
Old Sep 27, 2003 | 03:54 PM
ED8DX's Avatar
Default Re: Shifter counter weight was cut off? What to replace? (carsaregood)
I cut that thing off too, and I get a metallic vibration at wround 3500-4000 rpm. I think I'll just clamp it back on in a spot close to where it used to be.
Old Sep 27, 2003 | 06:30 PM
AgentJam's Avatar
Default Re: Shifter counter weight was cut off? What to replace? (ED8DX)
clamp the counter weight back to where it was cut? or clamp the rod that was cut to something?
Thanks,
Vince
dr_latino999
22
Jan 15, 2007 04:14 AM
erikiksaz1
Mar 28, 2005 01:51 PM
jolt-tsp
10
Jul 8, 2004 02:40 PM
charjacq
Apr 27, 2002 12:32 PM
