Supercharged LS/VTEC in 94' DX Hatch....
My buddies 94' Hatch with full interior, 18" inch wheels in the rear, 14" steelies in the front with AZenis ran a best of 13.8 last night. I just thought that car should be faster. The complete mods list is Hondata (tuned), DC 4-1, Basic tube style intake, ADJ. fuel reg., Stock LS Bottom end, B16 Head stock with stock B16 tranny with no LSD. He hit a good light .528, and a 60 ft of 1.9. What do you guys think? The Jackson Racing 10 PSI kit also.
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B_Something »</TD></TR><TR><TD CLASS="quote"> 60 ft of 1.9.
Thanks
1.9 60' on azenis?
Thanks
</TD></TR></TABLE>1.9 60' on azenis?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1320ForLife »</TD></TR><TR><TD CLASS="quote">1.9 on Azenis is pretty damn good.</TD></TR></TABLE>
That is what I was thinking, I haven't heard of under a 2.0 on street tires too much (don't even remember a seeing a 1.9, but drawing a blank right now).
1.9 60 foot is poor on that sort of tire. I have done 2.0 60 foots on crappy no name tires and so have many others. Dude is right. I would check your launch technique and practice on releasing the clutch. If you are just dropping it at the launch at high rpm you won't go anywhere. With a charger on there it will be easy to get wheelspin down low so work on applying the power.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S13Sean »</TD></TR><TR><TD CLASS="quote">1.9 60 foot is poor on that sort of tire. I have done 2.0 60 foots on crappy no name tires and so have many others. Dude is right. I would check your launch technique and practice on releasing the clutch. If you are just dropping it at the launch at high rpm you won't go anywhere. With a charger on there it will be easy to get wheelspin down low so work on applying the power.</TD></TR></TABLE>
I'm assuming you accomplished this 2.0 on your 240sx? If that's the case, it's pretty common for a rwd car to pull that kind of 60' on street tires. Hell, my buddy was doing 1.9-2.0 in his 1985 Supra consistently on shitty all reason radials. On the other hand, if you were refering to a fwd, then props to you cuz that's some elite driving ablities.
Actually 2.0 on a RWD car is even worse than the 1.9 on the FWD car. The 2.0 was done in my 1984 GTI 2L 16V actually.
Clips of the GTI
http://members.shaw.ca/seangreene/Sean1.avi
http://members.shaw.ca/seangreene/Sean2(1).avi
Modified by S13Sean at 9:11 PM 9/27/2003
Modified by S13Sean at 12:32 AM 9/28/2003
Clips of the GTI
about 3-4 years ago, i had a stock gsr in a hatch. jrsc w/ 8 lb pulley. afc, fuel pump, header, exhaust. ran the stock 99 si michelins and went 13.10. i was not driving it great, now i would think i would see 12.90's. it made btween 220 - 225 to the wheels. your friends set up should be in the 12's with the azenas.
Ya that was your event Clayton. I took 1st in that event. The car ran like crap actually and I was going to pull out during TT but my crew chief yelled at me and I went racing. Glad I stayed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S13Sean »</TD></TR><TR><TD CLASS="quote">1.9 60 foot is poor on that sort of tire. </TD></TR></TABLE>
2.4 is poor, 1.9 is very good on that tire in his car. Just because you got 2.0 60ft's on cheap all season tires doesn't mean anyone who doesn't do better can't drive. For a drag radial a 1.9-2.0 60ft is good, a more street type tire like the Falken with stiff sidewall would be good getting those same times.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt »</TD></TR><TR><TD CLASS="quote">
2.4 is poor, 1.9 is very good on that tire in his car. Just because you got 2.0 60ft's on cheap all season tires doesn't mean anyone who doesn't do better can't drive. For a drag radial a 1.9-2.0 60ft is good, a more street type tire like the Falken with stiff sidewall would be good getting those same times.</TD></TR></TABLE>
i agree in a honda if u cut a 2.1 or less IMO you are doing pretty good. As for a 1.9 on a Azenis, thats awesome.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i need space »</TD></TR><TR><TD CLASS="quote">1.9 on azenis is good...sounds to me more like something is wrong in this set up, not in the traction department</TD></TR></TABLE>
its got a supercharger
on the other hand...i had a stock b18b bottom with a 99si b16a head..ran 14.2 on street tires. (stock exhaust and cat) only had a short ram intake and a skunk2 chipped p28.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted99Si »</TD></TR><TR><TD CLASS="quote">
i agree in a honda if u cut a 2.1 or less IMO you are doing pretty good. As for a 1.9 on a Azenis, thats awesome.</TD></TR></TABLE>
hell yeah, i can only pray for a 2.0 60' the next time i hit the strip
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B_Something »</TD></TR><TR><TD CLASS="quote">The complete mods list is Hondata (tuned)</TD></TR></TABLE>
Any dyno numbers?
Any dyno numbers?
b20vtec214
19
Dec 2, 2005 12:30 PM
B_Something
12
Sep 27, 2003 12:28 PM
