removing pins from ecu harness plug
Old Sep 26, 2003 | 09:17 PM
Drew96EJ's Avatar
Default removing pins from ecu harness plug
what is the easiest way to do this? i have to move a wire and add a wire. pls advise. -drew
Old Sep 26, 2003 | 09:26 PM
ill phil's Avatar
Default Re: removing pins from ecu harness plug (tuner419)
Search the archives for VTEC wiring. I know I made a pic post, and I believe Katman and someone else did as well.
Old Sep 26, 2003 | 10:50 PM
dunkd's Avatar
Default Re: removing pins from ecu harness plug (ill phil)
a very small allen key or a paper clip...
Old Sep 26, 2003 | 11:06 PM
jameskersten1's Avatar
Default Re: removing pins from ecu harness plug (dunkd)
i hope i dont sound like a dumby but all i did was use the doner harness and a pin and push an pull like a bangee until it came out. hope that helps a little
Old Sep 27, 2003 | 08:01 AM
dwnthehatch's Avatar
Default Re: removing pins from ecu harness plug (jameskersten1)
https://honda-tech.com/zerothread?id=577367
Old Sep 27, 2003 | 08:07 AM
Drew96EJ's Avatar
Default Re: removing pins from ecu harness plug (dwnthehatch)
cool thanks i'll try that =]
Modified by tuner419 at 12:44 PM 9/27/2003
Old Sep 27, 2003 | 08:09 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tuner419 &raquo;</TD></TR><TR><TD CLASS="quote">cool thanks i'll try that =]</TD></TR></TABLE>
ok not sure what side you are using but did you remove the retaining cover on the harness yet? if not you are gonna be trying for sometime.
Old Sep 27, 2003 | 02:53 PM
Drew96EJ's Avatar
well, spent way too long trying to follow those directions....FYI: needle out of a sewing machine works perfectly. i got 2 pins out in like 1 minute
Old Sep 27, 2003 | 03:20 PM
ill phil's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tuner419 &raquo;</TD></TR><TR><TD CLASS="quote">well, spent way too long trying to follow those directions....FYI: needle out of a sewing machine works perfectly. i got 2 pins out in like 1 minute</TD></TR></TABLE>
Yeah I just used a needle for my how-to pics as well in the post linked after Katman's.
marcj
Aug 14, 2008 06:45 AM
recaroem2
Honda Civic (2001 - 2005)
Oct 10, 2007 09:59 AM
85mm LS VTEC
Mar 11, 2005 05:10 PM
navin
14
Mar 10, 2003 12:16 AM
RCautoworks
Feb 3, 2003 07:25 AM
