How Does it cost to a Tranny swap from AUTO to Manual on a 99 Prelude Type S
You mean a Base Prelude right? the 'S' model? Cause I'm pretty sure you don't own a Prelude Type-S
I have a 1999 Honda Prelude Type S...its the only other model except for Type SH..i have the one under that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PreLudE99L »</TD></TR><TR><TD CLASS="quote">I have a 1999 Honda Prelude Type S...its the only other model except for Type SH..i have the one under that</TD></TR></TABLE>
NO, you don't own a Type S, you just simply own the base model. The actual Type S is only offered in Japan, not here in the states. Do some research and see for yourself.
1) Your car is not a type-s
2) It's a base, somtimes referred to as an 'S' model but not a type-s
Let's move on. A manual tranny swap is a pain in the ***. I would recommend you sell the car and buy a manual before you attempt this crazy behaviour. Serious think about all the stuff you need from pedals to shift linkages to clutch/flywheel to slave cylinders shifter blahhhh just sell your car and buy manual.
just curious before any flames start, why do you think you have a type s? and ive been quoted 500 in labor for this job, and ive got 3grand in body mods, not to mention custom audio, and all the already installed mods which costed me thousands, why not just buy an awesome transmission and possibly a good lsd.
what else do you have to do if you have all of the parts, what would you guys do with the whole ecu imobilizer ****, has anyone attempted this??? i have a friend that needs some answers, so thanks for the help, and by the way, my friend owns a base model prelude, not a type s...womp womp!
just got done with mine.
I used a jdm front clip from a 4th gen. just a few things that you need to custom make. if you do this the same way as me you need a 97 and up trany bracket 72.00 from honda and a longer clutch line from the master cylinder to the dampener I paid 50.00 for braided stainless steel and got the clip for 2800.00
but now I have all kinds of parts to sell. I'll awanser any Q's you might have.
hth
Evan
hth
Evan
I cant use private message
but you just take the small light blue wire form the ignition relay and ground it. if you want it to start with the clutch depressed than run one wire form the clutch switch to ground and the other to the light blue wire. if your on your back looking stright up at the dash under the steering wheel the relay is to your right and has 4 wires coming from it three big gauge and one small blue wire.
hth
Evan
hth
Evan
Archidictus
Mar 16, 2003 03:26 PM
