Getting rid of the SRS light on --
Old Sep 26, 2003 | 06:06 PM
angelovargas's Avatar
Default Getting rid of the SRS light on --
My 2002 accord hit a pole and broke the srs unit controller(ironically the bags didn't deploy). My mechanic says he can install the srs unit controller, but I will have to take it to honda to have the ecu reset so that the lights don't stay on.
After my bitter experience with the Honda dealer(he's a shark). I'd rather do this on my own(that f**ker is not getting any more of my money!). Help!
thanks in advance!
Old Sep 26, 2003 | 08:15 PM
mwkirchner's Avatar
Default Re: Getting rid of the SRS light on -- (hondanoel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondanoel &raquo;</TD></TR><TR><TD CLASS="quote">
thanks in advance!</TD></TR></TABLE>
Solution: Reset the SRS funtion:
1- look underneath dash, near fusebox, for a 2-wire yellow plug, disconnect it and pull it down so you can work with it
2- turn ignition OFF
3- jumper the 2 wires together (cut paperclip in half and straighten, insert one end of both halves into back end of plug where each wire goes in, touch them together and hold)
4- turn ignition ON (SRS light will turn on for 6 seconds, then turn off)
5- within 4 seconds of SRS light turning off, unjumper the 2 wires (SRS light will turn ON)
6- within 4 seconds of SRS light turning on, jumper the 2 wires (SRS light will turn OFF)
7- within 4 seconds of SRS light turning off, jumper the 2 wires (SRS light will blink ON and OFF, indicating SRS function is reset)
Old Sep 27, 2003 | 07:23 AM
Default Re: Getting rid of the SRS light on -- (mwkirchner)
thanks a bunch, man! I will try it.
Old Sep 27, 2003 | 09:16 AM
soodark's Avatar
Is there any way to turn the srs light off when you have an aftermarket sterering wheel?
Old Sep 29, 2003 | 06:46 PM
mwkirchner's Avatar
Default Re: (soodark)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soodark &raquo;</TD></TR><TR><TD CLASS="quote">Is there any way to turn the srs light off when you have an aftermarket sterering wheel?</TD></TR></TABLE>
Unfortunately I know of no way to do this. The best you could do is remove the bulb.
Old Sep 30, 2003 | 05:00 AM
iakona's Avatar
you need to get a CMR hub that comes with the right fuse to fool the SRS unit to thinking the resisitor is still attached. very slick. i have one.
or remove your bulb.
datkins2
Feb 24, 2019 08:24 AM
Statkus
Jan 4, 2018 02:14 PM
Sergey.R
Jul 24, 2017 02:04 PM
Project Dex
Sep 4, 2005 08:14 PM
